what clutch?
That's before the discount also. I guess we are just in a different market or something?? Anyway, I just bought my 97 SS the end of last month and it already had a Duralast installed. It's holding up great so far even with the BMR LCA's and relo brackets, 4.10's, P285/40 - 17's and alot of bolt-ons. I'm really surprised how well the car hooks up and goes on the street. It's hard to just burn the tires on take off unless you do a clutch dump over 2500 RPM. Not true. The flywheel AND pressure plate (basically the entire clutch assembly) would be moved away from the trans whatever amount is macined off. You forget that the PP is directly bolted to the FW. What it will change is clutch engagemant height. Beinng that an lt1 uses a "puller" style clutch, it may work as an advantage and the clutch will release earlier.
Now if it is machined too much and the fork is actually preloaded and pulling on the throwout bearing, it will reduce clamping force just like driving with your foot resting on the clutch pedal.
A pusher clutch like a mustang or an ls1 can suffer from disengagement issues if too much is machined off. When the clutch is pushed in all the way, it my not be able to push the fingers in far enough to fully release the clutch.
Can yuo aactually take off enough to put bind on the fork? that seems almost impossable.
