name the part game!
Old Apr 14, 2010 | 10:40 AM
z28camaro1996's Avatar
Default name the part game!
what is this part and what does it do?
Old Apr 14, 2010 | 11:44 AM
flame's Avatar
Can't even tell what it is from that pic. Take a close up of it.
Old Apr 14, 2010 | 11:47 AM
1997b4c's Avatar
looks like the evap purge solenoid. which is part of the evap vacuum system.
Old Apr 14, 2010 | 11:54 AM
ill take a close up when i get home i found this pic on the net. would that cause the code p0400
Old Apr 14, 2010 | 11:59 AM
kinglt-1's Avatar
code po400 is a egr flow malfunction code. goin by the pic it looks like you circled the evap purge solenoid, again goin by the pic. The egr valve is located at the back of the intake manifold, on the driver side. You should have a egr solenoid and valve back there unless its been deleted...
Old Apr 14, 2010 | 12:02 PM
no its still there. every since the cats been gutted it threw that code.
the part i circled has a line going to it that come from the 3 fuel lines.
Old Apr 14, 2010 | 01:34 PM
RamAir95TA's Avatar
Need a better picture. On a stock f-body, the only thing in that area even remotely close is the fresh air supply hose for the PCV system.
Old Apr 14, 2010 | 01:38 PM
z_speedfreak's Avatar
ding ding ding! we have a winner
Old Apr 14, 2010 | 01:43 PM
RamAir95TA's Avatar
What's circled in the picture is not the EVAP purge solenoid. On the other hand, his description with the third fuel line makes one think otherwise. Perhaps the OP didn't circle the right part.
Old Apr 14, 2010 | 02:09 PM
I zoomed way in and your right, its not the purge valve but it is part of the EVAP system. I personally don't know its name or function. but if I had to guess it feeds the fuel vapors into the EVAP system since its plugged into what I assume to be the fuel line that takes the vapors.
so who knows for sure what its name & function is?
Old Apr 14, 2010 | 02:23 PM
djjab57's Avatar
Ive went and looked under my hood twice and there is nothing there.
Old Apr 14, 2010 | 03:12 PM
to help clarify ill take a pic of the part itself tonight.
Old Apr 14, 2010 | 07:36 PM
flame's Avatar
Here is a blow up pic http://shbox.com/1/1996_evap.jpg The part you are looking for is #11 I believe its called a purge switch. Basicly it lets the pcm know that the purge solenoid is working. They only started using them in 96 with OBDII.
Old Apr 14, 2010 | 07:55 PM
97camaross's Avatar
b/c your car is a 94 they started all that carp in 96... some one correct me if im wrong
AChotrod's Avatar
Yup part of the evap system and it will throw a code if its not connected or its bad.
Old Apr 14, 2010 | 11:04 PM
yep the part i was talking about in#11
