95' z28, TH400, Turbo tuning question
so i am about to finish my TH400 swap into my 95' z28, i need to know what i need to do as far as eliminating the check engine for the trans.... also i here LT1s are a bitch to tune... i am doing a single turbo and need to know what software or ECM to get to take care of all of the mods... smog is not a issue cuz i got a hookup on that.. anyhelp is grateful thanx
Buy Tunercats and TTS Datamaster. The LT1 computer is fine for boost to ~700 to the ground. I have Speed Density and MAF and my drag car males ~700 RWHP.
To do th 400 simply select stick trans. I will change my rearmount to a 411 but that is because I want to use a 4L80E. The Lt1 is ok as long as you kep the RPMs blow ~7200. You must tune your pwn if you use boost that is same for any setup.
The reason i say that is boost is needy for changes
Good luck
Good luck
