Crappy Windshield Wipers
Old Apr 21, 2010 | 01:41 PM
musclehead's Avatar
i went to every local auto parts store around and couldn't find any wiper blades that fit correctly on my 95 bird. However on my last trip I found a set at Kragen Auto parts, ANCO was the brand name. They fit and work excellent. They are quiet and streak free. Best damn blades I have used.
Old Apr 21, 2010 | 04:14 PM
my95LTwon's Avatar
Well.... I tried to bend mine and ended up just making them worse ha ha. I'm not too worried about it because I dont usually drive in the rain, but I think I'm going to be switching to 98+ as soon as I can find some.
Old Apr 21, 2010 | 08:40 PM
SoxXpupPeT's Avatar
look in the classified section here. i just picked up a set
Old Apr 24, 2010 | 11:24 AM
greendrazil's Avatar
Junk yards are the easiest place to get the arms. I got mine for $20
Old Apr 24, 2010 | 01:00 PM
ThoR294's Avatar
Next trip to the junk yard im going to get a 98+ set. the anco blades are ok, but the arms are just lame... and you have no variety of blades to use
Old Sep 2, 2010 | 03:07 PM
Hope this information helps those with the crappy LTx era wiper arms!
Old Sep 2, 2010 | 03:14 PM
djjab57's Avatar
Only ones i found to sit on the windshield right is the anco n=narrow
Old Sep 2, 2010 | 03:25 PM
Slowmaro95Z28's Avatar
I'm using 98+ wiper arms and expensive rain x blades. I have no problem with the blade not sitting flat on the windshield. Direct bolt on. No mods required.
Old Sep 3, 2010 | 01:41 PM
boosted99camaro's Avatar
I just put a slight bend in my wipers.work great
Old Aug 6, 2011 | 12:51 PM
Dave88LX's Avatar
My wipers suck, miss the huge area in front of my face. I guess I should get 98+ arms? Or is there anything else I need to buy to make them work?
Old Aug 6, 2011 | 07:08 PM
TAEnvy's Avatar
Guys pretty much any conventional wiper works on our car, If they are put on right. If put tons and tons of different wipers on these cars.
Our wipers suck because no one runs a conventional wiper now. Everyone has gone to a flat wiper, they are way better. Up until recently I ran them on everything but the camaro. Then I went to the junkyard found some LS1 wiper arms for free and now I will have my flat wipers.
Most flat Wipers like the Rain X Latitudes run around 20 a wiper but some auto parts stores have knock offs for 14-16 that still work pretty good. Ive always used the latitude, but Ive put the knockoff on customers cars and they still last longer than standard wipers.
Another trick is when you wash your car wipe down your wipers. Make mine last alot longer, and keeps you from rubbing trash into your glass over and over.
Picture for reference.
Conventional Wiper
Flat Wiper
Old Aug 6, 2011 | 07:34 PM
  #32
speed_demon24's Avatar
So instead of buying the correct wiper blades you guys are swapping out the arms?
Old Aug 6, 2011 | 08:01 PM
  #33
TAEnvy's Avatar
No I switched arms so I can run a Better wiper
Old Aug 6, 2011 | 08:33 PM
  #34
Dave88LX's Avatar
So are you saying run a conventional wiper and not a flat wiper? Or swap arms so we can run flat wipers?
Old Aug 6, 2011 | 09:41 PM
  #35
TAEnvy's Avatar
Im saying flat wipers are better if you feel like swapping arms.
The normal wipers I used to run would miss the more curved parts of the windshield and they sucked.
Old Aug 6, 2011 | 09:42 PM
  #36
shbox's Avatar
Post #6. No muss, no fuss. They work.
Old Aug 6, 2011 | 09:51 PM
  #37
5_LTR_ETR's Avatar
I cut the j hook off the end and flipped it over and re welded it on, and now I can use any wiper out there.
Old Aug 6, 2011 | 09:53 PM
  #38
SS#502's Avatar
That sounds like too much work!LOL!
Old Aug 6, 2011 | 09:54 PM
  #39
You were using the wrong blades then.
This. I haven't had any problems with any 24-9R's.
Old Aug 6, 2011 | 10:06 PM
  #40
5_LTR_ETR's Avatar
not much work and not much time... i got a $60 pair of piaa's new wipers for free from work and my wipers were ****. so it was well worth it for me
