CC503 or Lunati 60121?
Im looking to do some mild performance to my LT1 Buick GN
I am looking at either the CC503 or the 60121 by lunati. This is a street car/DD so Im looking to keep driveability and get best MPG. The car currectly has a 4l60E but I will be doing a T56 swap at the same time as cam swap. Rear gear is 3.73 and car has a nitrous kit.
specs on lunati
http://www.summitracing.com/parts/LUN-60121
CC503
http://www.summitracing.com/parts/CCA-07-503-8/
I will most likely be doing a mail order tune from pcmforless.com after the swap.
One of my good friends ports heads so I might pull the heads off and have him do them and the intake. What head gasket should I look at getting to bump compression up?
specs on lunati
CC503
First ovall the link you provide for the cc503 is not good.What it shows is the cc305.
Correct link:
I would go straight with the cc503.Has proven to be reliable and give good power even with stock head.
Impala gasket to raise your compression.
Correct link:
As stated before, both will perform well. My vote is for the 503 because it is just one of those good 'ol proven cams. Can't really go wrong. I was going to get a 503 for my bolt-on car before I started my 355 build....
And X2 on the impy gaskets...
thanks for the replies
JB can you list your mods to get 340 HP? thats where Im wanting to be is right around 330-350 on motor
anyone have any idea how much the impala gaskets help the c/r?
Lunati 60121, comp 26918 springs, 1.6 rockers, pacesetter longtubes and ORY. I replaced some other stuff while I was in there but shouldn't have gotten any more power out of replacing lifters, pushrods, and running an LT4 HD timing set. This was on stock compression as well
You won't go wrong with either. I ran the cc503 years back and that was an excellent street cam that really performed well on and off the track. The Lunati cam seems really nice too. Considering your going to get a mailorder tune I would imagine that there are way more files on cam only cc503 cars which would probaly be enough for me to choose that cam over the Lunati. Again, either way you can't go wrong. Just to add to the confusion you could also consider the GM846 which is a 222/230 .543/.563 on a 112 (1.6 RR's).
speedfreak - I should still be able to run regular with that little bit of bump in compression?
JB were those dyno #'s through a T56? you probably had a dyno tune with those #'s correct?
thanks again guys for the replies. heres a couple quick pics of the car its going in, kinda more of a show car but Id like to get a little more power out of it since moving its big 3800 pound *** down the track isnt working as well as I want it to haha
![](http://i59.photobucket.com/albums/g293/maoon88iroc/1983%20grand%20national/DSC00916.jpg)
![](http://i59.photobucket.com/albums/g293/maoon88iroc/1983%20grand%20national/DSCF0787.jpg)
![Icondrool](https://ls1tech.com/forums/images/smilies2/icondrool.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
anyways on the grade, I wouldn't even run reg stock never mind being cammed. but its the dynamic compression that dictates what fuel you need anyways. theres people running 12:1 on pump gas, it all depends on your set up. imo it would be smart to both bump up your compression and to have it tuned for 93 when you get it tuned after the work.
