Questions about oil pressure gauge.
I've heard the stock oil pressure gauge isn't very accurate and I want to install a mechanical gauge. I've done some searching and I still have a couple of questions.
1. Do you just hook up the gauge fitting in the plug above the filter?
2. Is this the best place to put it?
3. Is oil going to come pouring out?
4. Any advice since I've never done this before?
5. Can you recommend a good gauge?
I don't really plan on running this long term. I just want to hook it up and check and see how accurate the stock gauge is.
This is on a 97 Z28.
1. Yes
2. Yes
3. A little
4. Seal the threads of whatever fitting you put in there.
5. Any will do to check the stock gauge.
The stock gauge may not be very accurate, but it's a good general indicator.
2. Yes
3. A little
