Opti replacement gone wrong
Old Apr 26, 2010 | 06:24 PM
therealcreeper's Avatar
Default Opti replacement gone wrong
My Dad's friend (and current owner of my old 93 z28) had his Opti go on him. He replaced it along with the control module. Now the car will start but just barely stay running, and that's only if he keeps the gas to the floor.
Any ideas what he may have done wrong? Or what may still be broken? I only owned an lt1 car for about a month before it was totaled and he bought it from me, so I'm not real knowledgeable when it comes to them
Old Apr 26, 2010 | 06:25 PM
gregrob's Avatar
Plug wires on wrong is the most common. It COULD be installed wrong into the cam gear. It is possible even on the splined ones, happened to me once.
Old Apr 26, 2010 | 08:12 PM
SoxXpupPeT's Avatar
Unless the opti is a dud what gregrob said could be possible. its very easy to mix up those wires. and even tho you wouldnt think you could mix up the splined shaft you can.
Old Apr 26, 2010 | 09:16 PM
1994 TA's Avatar
and even tho you wouldnt think you could mix up the splined shaft you can.[/QUOTE]
So is there more than one way for the opti to go onto the shaft? I thought it had 1 way? Would this give you the symptoms of an engine out of time, (surging, backfiring and will not idle or tries to backfire thru the intake?) This is what my car is doing after the opti swap, will not idle, surges, sounds like it has a monster cam in it at 2000 rpm's. I am in the process of tracing the wires to see if I mixed them up (hope that is it).
Old Apr 26, 2010 | 09:46 PM
SoxXpupPeT's Avatar
So is there more than one way for the opti to go onto the shaft? I thought it had 1 way? Would this give you the symptoms of an engine out of time, (surging, backfiring and will not idle or tries to backfire thru the intake?) This is what my car is doing after the opti swap, will not idle, surges, sounds like it has a monster cam in it at 2000 rpm's. I am in the process of tracing the wires to see if I mixed them up (hope that is it).[/QUOTE]
its possible if you shove it on hard enough im sure. i had to double check myself several times when i did my opti.. what a PITA and mine is on its way out too!
Old Apr 26, 2010 | 09:50 PM
stevo9389's Avatar
the timing chain wasnt removed for any reason was it? i put a splined opti on 3 94 cars and it was very hard to screw up.
Old Apr 26, 2010 | 11:16 PM
1994 TA's Avatar
The opti slid right onto the the shaft. It took a good hour to find the sweet spot, but when I did it slid right on and went fully on. No the timming chain is untouched. Never went that deep.
