Spark Plug Boots Within 1/8" Of Collectors - Plug Wrap?
I am working on my install of Hooker shorties for the dual-cat LT1 system, and the collector on the drivers side is right between the 5 & 7 plugs. I had to bfh the collector to be able to even install the plug boot for #7 and now have about 1/8" gap. #5 is less than 1/8" gap but I haven't bfh'd that side yet. I have MSD 8.5 wires which have thick boots that are supposed to be heat resistant. I have some Thermo Tec Thermo-Shield wrap that I was thinking of putting on the plug wires. Would that, coupled with the thick MSD boots, be enough to protect the boots from melting that close to the collector? Pic below.
Btw, I HATE these headers.
Here is the best picture I have. Its the center two passenger side exhaust ports (4 & 6) that burnt the number 8 wire. I wound up using a number 7 wire and running it over the top of the 2,4, and 6 primaries. I also had the steering knuckle rub a drivers side wire down a good bit. The worst part of hooker shorties is I'm not sure its much easier than stock to change the plugs or route the wires.
http://s20.photobucket.com/albums/b2...t=100_0138.jpg
http://s20.photobucket.com/albums/b2...t=PIC-0049.jpg
http://s20.photobucket.com/albums/b2...t=100_0139.jpg
Just click the links I didn't want to jack your thread with pictures of my old stock lt1.
THanks for the pics. I should be fine in the areas where you had trouble. My wires are below the headers, tied out of the way, and in the eom heat shields. My only concern is the 5&7 at the spark plug boots. They are almost touching the collector.
I wrapped them in the fiberglass wrap I had and also pushed the oem shields on the boots. Hopefully that will be good, but I will keep check on them for a while till I feel more comfortable.
God, what a nightmare this has been. I would like to find the guy who designed these and beat him over the head with a set!!
Thanks again for the pics.
