guideplates
Old May 1, 2010 | 05:27 PM
redtransam95's Avatar
Default guideplates
i got a free set of new comp guideplates #4808-8 anyone run them and are there isues and if so what and what are the fixes short of buying new ones
Old May 1, 2010 | 05:50 PM
dangalla's Avatar
do you need them, are you switching to a non self aligning set up?
to answer your question they will work, with a 5/16 pushrod
Old May 1, 2010 | 06:20 PM
LT1's Avatar
LT1
You only run guideplates on NSA rockers.
If you run them with out NSA rockers youll get metal shaving all over.
Old May 1, 2010 | 06:22 PM
yes im going nsa
Old May 1, 2010 | 06:30 PM
LT1's Avatar
LT1
Are you gonna run harden, chromemoly pushrod?
This is the guideplates i used.
TFS-30400623-8
Old May 1, 2010 | 06:45 PM
dangalla's Avatar
TFS-30400623-8
you have to run hardened guideplates and chromolly pushrods
and that is the part number for trick flow guideplates
the number he has is for comp, and they will work fine
along with all the other viable options like gmpp, isky, ect.
Old May 1, 2010 | 06:49 PM
LT1's Avatar
LT1
Yup, theres many other guideplates that work too.
Just asking to make sure he is using correct pushrod
Old May 1, 2010 | 06:59 PM
RamAir95TA's Avatar
You need hardened pushrods to run NSA. They don't need to be chromoly.
Old May 1, 2010 | 07:11 PM
dangalla's Avatar
true, but with the cost of a nice set of trick flow chromolly pushrods i would not risk it
but you are absolutely right and i should have been more careful with my wording
Old May 1, 2010 | 07:40 PM
true and thats what i am going to run for pushrods anyone used these that can give me some insight on the fitment of these comp guideplates
Old May 4, 2010 | 04:16 PM
bump to top
Old May 4, 2010 | 04:18 PM
RamAir95TA's Avatar
Pretty sure your question was answered by shbox on another site.
Old May 4, 2010 | 04:22 PM
i want to hear from personal experiance go away if you have never tryed to use them
Old May 4, 2010 | 04:31 PM
RamAir95TA's Avatar
After 5 whole minutes of searching, they aren't hardened and don't align the pushrods properly. For $18, you don't get much. I would get the right pushrod guideplates, such as the Trick Flow 30400623-8. The reason you aren't getting much in terms of responses is because no one uses them (because they know how to do a search).
Just trying to help there, chief.
Old May 4, 2010 | 04:38 PM
how is saying my queston is answered helping
Old May 4, 2010 | 04:43 PM
RamAir95TA's Avatar
Is the sky blue?
Yes.
Is the sky blue?
Yes.
Old May 4, 2010 | 04:46 PM
TFS-30400624-8 or tfs-30400623-8 or do they both work
Old May 4, 2010 | 05:01 PM
suicidal racing's Avatar
i got the 623's
Old May 4, 2010 | 05:10 PM
by the way anyone who wants to know the comp guideplates ARE HARDENED
Old May 4, 2010 | 05:27 PM
RamAir95TA's Avatar
Hey man, go ahead and use them if you want - it's your car. It's an $18 part that could ruin your ****.
