Procharger with LE1 heads, how much boost......and more questions?
It's not an issue of "working" as much as being effecient. Boost is a result of there being pressure in your manifold/cylinders. The more pressure you have the more issues you will have with lifting heads or popping a hole in whatever your weakest link is. Not to mention how fast you have to spin your charger/turbo and where it's effeciency is. A more effecient motor will make the same power on lower boost.
Lets just say:
700 = stock heads/exhaust + 25psi
700 = stock heads/LT's + 22psi
700 = ported stockers/LT's + 18psi
700 = TFS 21*/single plane/LT's + 15psi
The easier the air flows through your motor the lower the amount of pressure you need and ultimately the longer your engine will live. Same thing can be said about cubic inches and RPM.
Lets just say:
This is just a curious question. Adding the nitrous wouldn't that just be the same as upping the boost with the turbo. Because the nitrous, if I'm not mistaken, when it reaches a certain temperature it releases all the oxygen which would increase the cylinder pressure. Correct? Isn't this the same as adding boost. Wouldn't someone that did this depending on how much nitrous they add with the turbo would need even lower compression pistons. If not could someone explain why?
this is a really good article from gm high tech regarding the relationship of na power and what it will make with boost, its a really good starter course for what your interested in here.
http://goo.gl/4jag
take a few minutes to read through it
http://goo.gl/4jag
http://goo.gl/4jag
http://goo.gl/4jag
Since you think ~12.7 1/4 makes you an expert racer (LMAO) now you know power train loses tell us what power train loses he should expect on his setup?
Please take your own advice and STFU. 12.7 is not racing I would need to coast from 60 foot to go that slow. In fact I did a launch and coasted to a 7.9 your car hasn't even been that fast WOT.
People you can believe what you want I don't care who you believe, I just don't have time for morons anymore and as I said he is King of the Morons.
Once he answers try posting in the adult section (Forced Induction or Power train) to verify his answer.
Good luck
I am from New York moron. In a 50 50 world how are you almost always wrong?
Give your answer!
What should he expect to lose? If 20% is way off post what it is, so it can be verified or do what you recommended and STFU
You don't have the ***** to answer because you have no clue!
I am SICK of you making stupid statements. Back up what you say or STFU
Is that clear I think what you posted is WRONG and challenge your statement. Answer the question or move on.
I think he said if both done basically they won't ever leak. Meaning something else becomes the weak point. For 'normal' people I thinki head or block o ring is affordable and all we need.
Yeah that is why I was wondering how much boost I need to reach 700rwhp Since I only have LE1 heads, I knew I would need more boost to reach my goal compared to an aftermarket ported head.
So definantly go with copper gasket 0-ring heads. I will be constantly researching for the next year and a half.
#32
I don't care who you referred to, your statement is WRONG. Quit spinning and answer what the loses are we heard what you think it isn't so give the thread the answer.
2 my original statement is that it doesn't take 200hp to run a drivetrain. And its correct whether you like it or not.
EAD
#33
You ARE wrong!
The higher the hp the greater the loses. PERIOD. The powertrain loses are not a constant.
#34
LOL not trying to get in on the name calling but I don't see how 1000rwhp loses 200rwhp
#35
#36
Interesting post on the matter:
https://ls1tech.com/forums/4446970-post8.html
Specifically from that post some quotes:
If one were to have a system with an input of 100 lb-ft at 100rpms, with an associated loss of 10 lb-ft measured at the output, this would of course represent a 10% drivetrain torque loss. If one raised the input torque to 150 lb-ft at 100rpms, one might expect the 10% loss to result in 15 lb-ft reduction at the output. In nearly all cases, this is not the result. Less than the expected 15 lb-ft will be dissipated as additional heat. This would represent an increase in rated mechanical efficiency. Why would this be observed?
It is observed because the energy dissipated, while strongly influenced by sliding friction (which itself is not a purely linear relationship to imposed loading anyway), is not solely dependent upon gear friction; which is all that has changed by adding 50 lb-ft more to the input.
#38
Saying something is wrong is easy but not helpful if you can't discuss why it is wrong. There isn't one answer and often you must use swags that is the real world.
Good luck
#39
Here is my opinion:
With the drivetrain loss you will see, you will need an F1 blower to reach 700rwhp without too much boost (~15psi). If you have a D1, it's doable, but you are gonna spin the **** out of it (20-22psi).
A T76 turbo setup will easily get ya to 700rwhp @ 15-18psi (depending on the kit).
I think if 600rwhp is goal, then it is achievable with a D1 @ 15psi...
