Swapping my Vortech for N2O...
I've been running a supercharger setup on my LT1 for a while now, Vortech S-Trim 9PSI, with fully forged internals- 8.8:1 pistons, crank, c-rods, clevite bearings, etc... fuel pump and injectors are upgraded. i'm running a 214/222 .488/.509 112LSA crane cam, HI-6S ignition, full exhaust, etc
I was wondering, if I were to take the blower off and sell that and the tubing, buy a CAI (and change belts, etc), what else would I need to change to run N2O? How high of a shot would my blower-built internals be able to handle? I don't know much about nitrous, but I'm pretty sure that a higher compression ratio would be better... correct?
If I can get enough money out of that, I'd like to swap my edelbroch midlengths for some hooker LTs, a higher stall TC, heads, and an N2O system.
Help me out a lil, add some thoughts on what else I'd wanna change. Thanks for the feedback.
i replied on camaroz28,and just too lazy to retype it
any questions feel free to ask.
Honestly if you can't afford the intercooler then I wouldn't try and stretch every last penny out to get your car into the 10's. That's when things start happening, and next thing you know you have no car!
Keep the s-trim and save up for an intercooler - you can pick up an ATI 3-core for <500 bucks if you look around - just do a frount mount with that and you are good to go.
Chris
Basically what I'm saying is, the number one reason for this is because of my lack of ability. Number 2 would be money.
At least, those are my long term plans.Thanks for all the comments, guys
The cost of adding the intercooler will be far less than a good and complete N2O set up.
A well tuned 355 with good heads and a decent cam running 12# of boost (even without an aftercooler) will easily make ~550rwhp through an automatic like yours. Thats plenty to acheive your goal of 10's.
IMO, you might wanna swap that peanut cam out of there for something with a little more lift. Something along the lines of an XE224/236 on a 114 LSA would work very well.
Sounds expensive doesnt it? Well, to get similar power numbers out of an N20 setup on your motor would probably cost about the same, if it were acheivable, cosidering you already have the Vortech. Nitrous works best with lots of compression and a cam with lots of exhaust duration and some negative overlap. Also, nitrous loves lots of compression. The motor you have in that car is much better suited to boost than spray IMO.
FWIW, if you cant afford heads just yet, 10's are probably still acheivable. Buddy of mine here in NC has a 9.0:1 355 with STOCK heads, a 224/236 cam and an ATI P1SC running 8# that makes around 470 rwhp and runs 11.3's at 121 all day long.
Richard Krause made over 600rwhp with a 214/224 114 cam with 7"/2.85" blower combo, INTMD8 on this board made 634rwhp with a 214/224 (I believe, could have been slightly smaller on the exhaust) and I think a 7"/2.75" blower setup.
S-trimmed maxxed out should bigve you around 14lbs of boost on your motor and over 600rwhp with proper tuning - if the heads are unported you may have them worked on at some point - otherwise, just get an intercooler and pulley up. If you just don't want to do an intercooler you can always do water/alky injection.
Really not a good idea to go to much bigger with your blower - you will just start blowing intake out the exhaust and not make much more if any power. LJ ran 9's @ 139mph with his s-trim - through a TH400!
I've always thought the lsa on my cam was a little low... it's 112*, what is your redline set at right now?
I posted in here to get advice on the best route to 10s, more or less. I wanted to know if it was worth selling the blower and going down the N/A road with nitrous instead of staying F/I. People like Chris, Hellteeone, and Unit have given me lots of helpful advice on the matter, and I've decided to stay F/I for now. You, on the other hand, came in and took a shot at me while providing no helpful advice whatsoever.
Let's take a look at the advice you've given me:
1) Dyno tune her
2) Do a full length header swap
My answer for that is NO ****.
Thanks for your help
1) Dyno tune her
I guess it is possible but you would have to know a lot more about what you are doing then you do. Let me know when you get there.
You really want to run 10's on the cheap? 1. Sell Blower
2. Buy Beater
3. Buy a cheap n2o setup
4. Buy wheels/tires/headers/converter/whatever
5. gut the car or just swap everything into a gutted thirdgen
6. go racing and hope they don't notice that you don't have most of the safety equipment needed
7. pray nothing breaks
My advice for now.. sell the blower on ebay, keep the 2K and be able to afford gas/insurance and optisparks and worry about "running 10's" later.
And what was wrong with my original advice.. ? I didn't see any part about how you needed advice on how to run 10's with what you have now and $300. Maybe I missed it in the original post.
I beleive that Richard Krause is running some high lift variation of the 224/236 cam on his new F1 setup. Not sure about that though.
The water/alky injection works best on a blower setup where the blower is pretty much maxed out to start with IMO. At 9# he is not spinning the blower really hard and creating a lot of heat, therefore he may not see a whole lotta gains. A few months back we tried a meth/water setup onmy buddy's Mustang. He was running a Vortech t trim on a stock shortblock heads/cam/intake 5.0, making 10# (around 500rwhp). Since a T-trim is working pretty efficient at 10# to start with, he did not see much of a gain at all with the alky. Actually, on a few pulls, it lost power. Hmmm, maybe FMU's and alky dont work well together, since the FMU makes it rich up top to begin with.....
It's really easy to run too much water/meth and lose power also. That could have been where my buddy and I made a mistake with it. Oh well, live and learn as always, he swapped a lil bitty Powerdyne on that car now (T-trim went on his other car)...maybe we'll try shooting just water into it now with an FMU and see what it does...either that or spin that Powerdyne really hard to make close to 10#, **** can the FMU, and use water and alky...
