Fuel Line Leak - Intake Hot
I finished my header install last week and have been driving the car since. It has been running without incident, but today I noticed at lunch and after work that it was just a little bit slow cranking. I also noticed the smell of fuel around it. This evening I was out in the garage and popped the hood. I noticed that the larger fuel line is leaking a bit near the rear of the intake. I started feeling around and put my hand on the fpr and noticed it was HOT!! I then put my hand on the intake and noticed it was also hot. Too hot to keep my hand on for even 1 second. And the car has been sitting out there for over just over an hour. I can put my hand on the headers and they are much much cooler than the intake and fpr. WTF!!!
Perhaps your fuel pressure regulator took a dump. Pop off the vacuum line and see if any fuel comes out when you prime the system. Also, get a fuel pressure test gauge to verify whatever is going on back there.
I checked the vacuum line. No gas smell there. That fpr only has about 3k miles on it. I can tell where the leak is. My main concern here is the heat of the intake. I never noticed it taking that long to cool down. Is that normal for it to be hot long after the headers are cool?
Sounds normal to me to be honest. Engine bays get warm, and there likely isn't much air circulation up under the cowl.
Where is the fuel coming from, the connection on the fuel rail? I'd definitely have that fixed ASAP - that's a fire waiting to happen. How much is leaking?
