Flat or square O2 extensions?
Old May 10, 2010 | 09:36 PM
Johnny-LT1-runner's Avatar
Rockstar
Default Flat or square O2 extensions?
Simple question. Any takers?
It's a 94 BTW, so I only need fronts, but do I need one or two extensions seeing as how 94's only had 1 cat?
Old May 10, 2010 | 09:39 PM
Smoke Em's Avatar
im pretty sure you need two flat 12" extensions
Old May 10, 2010 | 09:40 PM
RamAir95TA's Avatar
Flat!
Old May 10, 2010 | 09:42 PM
Rockstar
Cool, I always trust what you say RamAir, do ya know if I need one or two?
Old May 10, 2010 | 09:51 PM
TheTransporter69's Avatar
what are you doing long tube headers? I had a 12" and a 24" on the passenger side
Old May 10, 2010 | 09:54 PM
Rockstar
yeah, goin to some ebay stainless LTs.
Old May 10, 2010 | 10:21 PM
xdanny510x's Avatar
cant u just cut some primary wire and grimp em together with some connectors and heat shrink/./?
Old May 10, 2010 | 10:30 PM
Rockstar
I could, but if it falls apart down the road I'd just be kicking myself for doing something half assed when I could have gotten it all done the right way the first time. And it'll look better this way, like factory, kind of.
Old May 10, 2010 | 10:31 PM
RamAir95TA's Avatar
You could, but some people argue that crimp connectors affect the resistance values of the wiring.
Old May 10, 2010 | 10:39 PM
BlackBird87's Avatar
Whats your opinion on it?
Old May 10, 2010 | 10:54 PM
RamAir95TA's Avatar
I have extensions for mine. I wouldn't cut and crimp any signal wires.
Old May 10, 2010 | 11:17 PM
fex77k's Avatar
The cheap *** wiring kit that came with my pacesetters was all the persuasion I needed to get extensions as well.
Old May 11, 2010 | 07:05 AM
shbox's Avatar
You don't ever want to alter the wires attached to the O2s. They are an important part of how the O2s work by drawing in reference air between the wire and insulation. They also use stainless steel wire. If you want to do your own extending, do it on the car's harness side. Extensions keep you from hacking up the car's harness (always a good thing).
Old May 11, 2010 | 07:22 AM
FASTFATBOY's Avatar
You really only need one, on the passenger side. You need the flat one. I got a new one for sale.
Old May 11, 2010 | 07:41 AM
1badzee's Avatar
Yeah you only need a few inches on the pass. side. Depending on your setup, driver side should fit fine (mine fit but was a bit tight so I made my own extensions. Like 8" on one side and 10" on the other side, way too long but it works.. one of these days I'm going to re-do them for a perfect fit)
Old May 12, 2010 | 05:33 PM
Rockstar
I ordered 2 24 inch extensions the other night. If I end up not needing one I'll just put it in the sale section.
Old May 13, 2010 | 01:37 AM
Wicked94Z's Avatar
im late to the party. but it amazes me that people cant just look under the car and see what kind of connector they need.
Old May 13, 2010 | 01:49 AM
Rockstar
It's just easier to ask people who know from experience than get it on jack stands and get coated in oil.
Old May 13, 2010 | 06:59 AM
1badzee's Avatar
Dude, that's 2 feet of an extension.... Where would you ever need that?
Old May 13, 2010 | 01:25 PM
Rockstar
I didn't know if I would need one or two, so I played it safe. It's just wiring.
By Brett Foote | 2026-06-04 05:00:17
