Lt4
Im 100% sure its a 4 bolt main as Im using it for my forged bottem end build and I use it all the time to mock up heads and intakes for port geometry.
The one in my 94TA was a 2 bolt and pops 355" was a 2 bolt, oh well it dosnt make a damn difference anyways.
Listen to everyone here and dont **** around looking for one of these 4bolt blocks, just get your 2 bolt setup splayed or studs and it will be overkill for 99% of the power you will ever make. Im reusing my 2 bolt block and having it refreshed with hone/rings and bearings and oil pump and Im still going to spin it to 7500rpms. I would rather save the 4 bolt for nicer forged parts since I already have it laying around and would hate to kill it with stock parts.
I put it in my bird and im really happy with it
Always was a sucker for special factory parts, like the LS6-LS7 rectangle port bigblock heads I wish I never sold to buy a beautiful back door and stainless fridge for the kitchen lol. Oh well cars are around always family is more important...
Somewhere on youtube, there's a video of heads being bolted down by machine with blocks coming down one line and heads another. Machined parts in one end, assembled engines out the other.
Other than today's LS7/LS9/LSA engines, which are hand built, it's still the same.
Im talking about the crankshaft with undercut and rolled fillets giving much better bearing tolerance's and creates the high tensile strength point to make the crank design more stout. Has a roller timing chain with steel gears not powered metal like LT1. Different harmonic dampener and as you know superior as cast heads, who wouldnt like to have a set of those sodium filled valves to toss in there LT1 heads??? Fractured cap rods in all the LT4's that the later year LT1 also have as I have three sets of those un machinable piles of scrap
Im not saying they are not mass assembled just better machine work that Im 100% sure of. After holding a lt4 rotating assembly in my hands and a LT1 setup directly beside it using a micrometer and depth calipers you can clearly tell its better machine work over LT1.
Im not nuthugging on the LT4 but I wouldnt toss it out of bed if one made the moves on me
Lets not forget about the nodular iron main caps that im sure were not needed but is nice to have over a two bolt block, teflon rear main seal to rid of the common leaking LT1 design.
A guy started a thread on stock LT1 timing set reliability and let's just say that even on setups like mine the LT1 set was shown to do the job WELL. So again a "upgrade" of questionable tangible benefit.
The valves are nice I will give it that BUT modern springs let us get away with a LOT before needing something so exotic.
