What heads and Cam?
small runners work better with smaller cams? really? what about l92s in 5000 lb trucks that get 20+ mpg? small heads need MORE cam, bigger heads need LESS cam. I'll put my AFRs against your peanut port trick flows for under the curve and peak torque any day, that's not a shot at your build, i'm just saying smaller isn't necessarily better.
. Big heads needs a big cam PERIOD!!! P.S. I love cruising my city with my HOT CAM without all that cam surge... Last edited by NewOrleansLT1; Jun 1, 2010 at 01:00 AM.
https://ls1tech.com/forums/generatio...ments-rpm.html
Runner size does not dictate air velocity or low end tq. An LS3 has 260cc intake runner and can make 500rwtq with a baby 22x duration cam.
Doesn't sound lazy to me at all.
In a very brief nutshell, good flowing heads allow you to run less cam. Crappy heads require more cam to bandaid the shitty flow of the heads and feed the motor its CFM requirement.
i'll speak from experience. fastfatboy should come in and talk about his experience with a 245cc head street car, the one he drives to the beach, and the one he drives to the track to run mid 10s.
