What heads and Cam?
Old 05-16-2010, 01:55 AM
JeaneGrae's Avatar
Default What heads and Cam?
My brother is trying to turn his 94, m6 Camaro into a formidable street machine. We need help building this monster. Would you guys lean towards an lt4 hotcam kit with trick flow heads or go with an AI or Lloyd Elliot Stage 1 or 2 set up. Either pkg would have supporting full exhaust, lca, panhard, and sfcs, with a dyno tune. Any inputs would be usesful. Also what gear ration would you consider, he currently has a 3.42 set up. thanks!
Old 05-16-2010, 02:00 AM
RamAir95TA's Avatar
Ported 200cc stock castings from www.advancedinduction.com with a matched custom-grind billet cam, along with 4.10 gears will HAUL ***. I'd poke a nod in for Lloyd Elliot too, but he's been having some minor issues lately.
Trick Flow heads with the hotcam will be an absolute dog and a waste of money.
Old 05-16-2010, 02:11 AM
JB_97ws6TA's Avatar
really I would like to hear more about that last statement...please go on
Old 05-16-2010, 02:23 AM
RamAir95TA's Avatar
In addition to the reduction in compression due to the TFs having much larger combustion chambers, the standard run-of-the-mill hotcam will be hard-pressed to make use of the additional port volume. There's just no need (or use) for so much head potential with such a little cam.
The TFs are nice and all when ported and milled, but using them as-cast and with a small cam will pull down static (and dynamic) compression. Those heads really shine in the hands of a good porter though. I'm not dissing the TF heads, I'm dissing the TF heads mated to a hotcam (or any other smallish cam for that matter). If you're after sheer power and are cool with just tossing parts together, it'll work, but that's about it.
Old 05-16-2010, 03:48 AM
Wicked94Z's Avatar
this...
Old 05-16-2010, 12:54 PM
JB_97ws6TA's Avatar
ok I see where you are coming from if you are talking about their 195s but I am sure you are aware that trickflow offers more than one set of heads for the lt crowd. Their 21* heads have 54cc chambers and work pretty good with smaller cams due to the small runners and would not drop compression. Granted there are heads out there that will make more peak power but these heads are a good value for 1500 and seem to be pretty good performers from the limited amount of information that has been released
Old 05-24-2010, 09:13 PM
LS1TECH Sponsor
NightTrain66's Avatar
curious at to any issues I have had recently.
I feel fine, no health problems and I am doing great.
I have been swamped with work and no time for the forums lately but is there anything more to this story than that?
Just wandering.
Lloyd
Old 05-24-2010, 10:18 PM
Hackscamaro's Avatar
the motor i just built last summer is AI's 190 heads and their 226/234 cam and it makes amazing power clear through the powerband and makes some very very good torque. o and i drive it every day 60 miles round trip. super streetable. i have 4.10s with my m6 and love it
Old 05-24-2010, 10:28 PM
carlos64030's Avatar
What kind of times are you running with your setup?
Old 05-24-2010, 11:16 PM
JB_97ws6TA's Avatar
FWIW I have trickflow heads and a cam very similar to a hotcam
Old 05-24-2010, 11:20 PM
StealthFormula's Avatar
I have been running an LE2 H/C/I package for the past couple years and it has been great. It performs very well on and off the track and it has been money well spent. IMO, a stock ported heads/cam package from any reputable vendor will be all you guys need to make a fun and powerful street car.
Old 05-25-2010, 09:09 AM
Puck's Avatar
Either LE or AI package will be a hell of a lot better then a hotcam with off the shelf heads. If you do not want the downtime from a porting service, a cam like the 503 with 21* TFS heads should be a lot of fun on the street.
Lol everything from LE seems to be making gobs of power lately, I have not seen or heard of any issues at all.
His stuff keeps getting quicker and quicker no matter how swamped he is.
Old 05-25-2010, 10:44 AM
NewOrleansLT1's Avatar
+1
Old 05-25-2010, 10:55 AM
The Hot Cam and the CC503 makes similar power...
Old 05-25-2010, 11:23 AM
stumprrp's Avatar
i have the 195 TF heads on my 396 with a pretty small cam (236/244) for a stroker and it makes crazy *** power everywhere, runs out of gas around 6500.
Old 05-25-2010, 11:39 AM
Puck's Avatar
The 503 will make more power then the hotcam even on stock heads. Let it breathe and the discrepancy increases.
Old 05-25-2010, 11:53 AM
Yup, a solid 10rwhp more on stock untouched heads.
Old 05-29-2010, 02:47 AM
You do mean 'UP TO' 10 more rwhp right?
Old 05-29-2010, 02:21 PM
If you take two identical cars, one with a hot cam and the other with the cc503 and put them on the dyno, you can expect the 503 car to put down about 10rwhp/tq more give or take a couple.
Old 05-30-2010, 10:23 AM
Wicked94Z's Avatar
no.... the hotcam is the best cam ever. im going to put one in my new motor because i want to go really fast!
Quick Reply: What heads and Cam?
