Progress was made today!
Old May 29, 2010 | 02:22 PM
  #41
SoxXpupPeT's Avatar
thats coming along Very nicely! engine looks great
Old May 29, 2010 | 02:24 PM
  #42
FASTFATBOY's Avatar
Originally Posted by Puck
Still looks slow, you should do a turbo b16 swap. I hear from the high school kids that they are the fastest things around .
Twin turbo YO! twin 60's on a B16, I got yo slack!
Old May 29, 2010 | 02:28 PM
  #43
FASTFATBOY's Avatar
Well the carb hat I WANTED wont fit.....The EV hat is too tall.
SO I ordered the Spectre hat thats 3.5 tall vs 4 for the EV hat....but DAMN that big EV hat looked WICKED on there!
And I am gonna have to HOPE it fits, I think it will when I notch the rear of the hood.
Old Jun 2, 2010 | 09:33 PM
  #44
FASTFATBOY's Avatar
Little bit further tonight
I know I been slacking, I am old and gimped up.........
Here is where I decided to mount the Safeguard
Old Jun 2, 2010 | 09:53 PM
  #45
gregrob's Avatar
**** is weak.
Is that safeguard the knock alert? Id like to know more about that system.
Old Jun 2, 2010 | 09:55 PM
  #46
FASTFATBOY's Avatar
Originally Posted by gregrob
**** is weak.
http://www.jandssafeguard.com/
Old Jun 2, 2010 | 10:06 PM
  #47
gregrob's Avatar
Much obliged.
Old Jun 3, 2010 | 06:15 AM
  #48
z_speedfreak's Avatar
that gadget is pretty cool!
Old Jun 3, 2010 | 08:44 AM
  #49
Formula383's Avatar
Lookin good! Did you take any pics with the hat on it?
Old Jun 3, 2010 | 09:12 AM
  #50
FASTFATBOY's Avatar
Well I bought an EV hat for it and its too tall, I want to keep my hood and intake setup I have now. I will have to notch the rear of the hood with either one.
I have the Spectre hat on the way now, its a 1/2 inch shorter but with a 4 inch inlet vs the 3.5 for the EV hat.
I wanted that EV hat, that thing looks wicked.
Old Jun 3, 2010 | 09:09 PM
  #51
FASTFATBOY's Avatar
Chuggin along, I dont think this is gonna fit....it MIGHT. It was my last option.
If it doesnt I have a buddy who will swap hoods with me and I can put a LS1 lid setup on it. It is a 2.5 inch cowl hood he has.
Old Jun 3, 2010 | 09:26 PM
  #52
robsquikz28's Avatar
Stock hood and that bad *** setup aint gonna happen.
Old Jun 3, 2010 | 09:31 PM
  #53
Tapout911's Avatar
Could lose the spacer and clear up some room. What did you do with the EV hat? I have tons of clearence
Old Jun 3, 2010 | 09:46 PM
  #54
FASTFATBOY's Avatar
Spacer has to be there for the throttle to swing over my fuel rails.
I am trying to keep the hood I have always had.
Old Jun 3, 2010 | 09:47 PM
  #55
FASTFATBOY's Avatar
Still have the Hat, its brand new.
Old Jun 3, 2010 | 09:56 PM
  #56
Puck's Avatar
Think it would be possible to make a bracket for the linkage to rise it up enough to clear the fuel rails without the spacer? It would fit for sure without it.
If you can't, have you thought about notching your hood and fiberglassing on one of those small 2" or so fake cowl scoop things like the ones Harwood make? You could mock it up to keep your intake setup and it shouldn't look too bad. That way you won't have to worry about messing with your intake setup, and it would be cheaper then buying a lid setup unless you and your friend swap hoods and intakes and you can do it for basically free.
Just tossing out ideas.
Old Jun 3, 2010 | 10:09 PM
  #57
FASTFATBOY's Avatar
I can notch the rear of the hood, but it is still gonna be close.
Old Jun 3, 2010 | 10:10 PM
  #58
FASTFATBOY's Avatar
It will clear everywhere but in the rear, I already knew I was gonna have to knotch the rear of the hood. If you look at a hood like ours in the back there is 2.5 inches where it drops down to meet the hood seal at the rear. I can notch that, but even if I do it will be VERY CLOSE.
The throttle deal is a no go, when the cable pulls the arm it swings down and around on the bottom to pull the rear flaps open. The fuel rail was notched a little and has minimal clearance to swing.
See here.
Old Jun 3, 2010 | 10:37 PM
  #59
1badzee's Avatar
As long as it fits. It all depends on how clean you want it. My lid conversion was a pain. The hood closes but I push down on the lid a tad (real tough to close), but it works lol. Different situation, same concept. Unless you're saying that the cable arm won't swing all the way with the hood closed, then that could be an issue.. Hopefully it all works out, if not, maybe a new hood is in order. Good luck!
Old Jun 3, 2010 | 11:42 PM
  #60
MasterTomos's Avatar
Lovin the way the intake looks! good work...good luck with the hood
