Another Cam Only Dyno Result
Old May 23, 2010 | 12:07 PM
Spiers's Avatar
Default Another Cam Only Dyno Result
96 WS6 M6, Comp Cam 230/236 112, 1.6rr, Patriot gold dual springs, Pacesetter LT, 2.5" Ypipe open, free mods. Everything else is stock. Mail order tune from Madtuner. What do you guys think...
http://www.youtube.com/watch?v=RbMqiLUOWIM
Old May 23, 2010 | 12:10 PM
RamAir95TA's Avatar
Nice numbers for cam-only. What's it run at the track?
Old May 23, 2010 | 01:30 PM
Spiers's Avatar
Waiting on gears and a tire for that. Still have stock gears...will be doing SVO #30's and an EWP, a 8.8 with 4.10's and a drag radial...hopefully by the end of the summer. Full weight 3550 without driver.
But it did run 13.0 @110 with a 2.2 60ft ....
Old May 23, 2010 | 01:36 PM
SoxXpupPeT's Avatar
thats damn impressive for a cam only + bolt ons...
Old May 23, 2010 | 01:45 PM
WhitePhoenix99's Avatar
Damn 13.0 @110 with a 2.2 60'?? Nitrous? lol
I've been looking for numbers for this cam, sounds like a strong runner. How's the driveability?
Old May 23, 2010 | 02:43 PM
carlos64030's Avatar
Cam only?!?!?! Wow... those are some impressive numbers for so little done. I plan on going with the same cam pretty much, but I have AFR LT4 competition ported heads.
Old May 23, 2010 | 03:43 PM
SpeedDensityZ's Avatar
Looks like the tune is pretty good, I wouldn't mess with the injectors unless you have the fuel pressure jacked way up to get it run right. Save the money for mods somewhere else.
Old May 23, 2010 | 03:47 PM
SS MPSTR's Avatar
Your car obviously responded very well to what you've done. Nice.
Old May 23, 2010 | 04:48 PM
Wicked94Z's Avatar
there's some hp on the table above 4700, you can see the tq curve take a slight hit when it starts to go rich. email the dyno sheet back to ion and he can probably fix that right up for you. Honestly we're talking about 5 hp here, but still it made great numbers as is. You can see the nice torque this cam makes over a cc306 with that wild split, and it probably only gives up a few hp up top which seems like a good trade-off.
Old May 23, 2010 | 10:15 PM
Spiers's Avatar
I already have the SVO #30. Just waiting on the funds for a rearend with gears so I can retune all at once, up my idle to 800, and have Ion touch up that A/F! The tuner said I should be at 13 instead of 11-12. Driveability is good unless I'm trying to cruise low in 1st... but that's because I have 3.23 gears
Old May 23, 2010 | 10:33 PM
Wicked94Z's Avatar
i like those wheels too BTW, clean looking car
Old May 23, 2010 | 10:37 PM
1961ba427's Avatar
Very impressive. Subscribing in hopes you update this thread when you get through with the injectors and re-tune.
Old May 24, 2010 | 04:53 AM
MICHZ28's Avatar
This cam also has faster ramp rates than the 306 so that helps with the torque too.
I plan on running the same cam but with a 110lsa
Old May 24, 2010 | 10:05 AM
StealthFormula's Avatar
Great results. That is an excellent cam, not too many people run it but they all have had great results from it. I see no need to run the cc306 when you can get similar numbers with the XE 230/236 and have more torque and better driveability.
Old May 24, 2010 | 05:14 PM
Spiers's Avatar
Thanks.
You're right... I don't see many people run this cam. That's a big reason why I chose this one. Plus the exact reasons you just stated, not to mention I really like the lope it has to it. Everyone has a cc503 or cc306 so this one is sort of in-between.
Old May 25, 2010 | 12:03 PM
chavez885's Avatar
Nice numbers!
Old May 26, 2010 | 07:45 PM
lethal bird's Avatar
nice numbers im looking in the this cam myself.
Old May 26, 2010 | 08:51 PM
1989GTA's Avatar
Not bad numbers at all. However IMHO your car is running rich looking at the graph and has more power in it. Looks like it is around 12:1 and goes even richer above 4800rpm. You stand to gain more power by getting the AFR around 13:1.
Old May 26, 2010 | 09:39 PM
Spiers's Avatar
I agree.... I wonder how much though
Old May 27, 2010 | 09:11 PM
1989GTA's Avatar
Hard to say but I would bet on 10+ rwhp at a minimum.
