dyno question
Old May 26, 2010 | 05:30 PM
SPRAYED Z's Avatar
Default dyno question
Well my car was tuned last year and its being tore apart right now anyway> But how much more power could I have made with the correct AFR?
I have full bolt ons with a 52mm bbk, 3600 stall stock 3.23 gears and It made 291hp and 323 ft lbs. Does this sound right? This was also with a custom cam of 226*234 .565 lift 110 lift.
AFR at full throttle was 13.8. Could I have made more power than what I had or what.
Old May 26, 2010 | 05:42 PM
bore.me's Avatar
I made 274 hp with the mods in my sig, no cam. So maybe yes?? Hope that helps
Old May 26, 2010 | 06:57 PM
1SWT95Z's Avatar
Is this an auto car? What bolt ons do you have besides the cam?
Old May 26, 2010 | 07:01 PM
chasgiv3's Avatar
Unless their putting stalls in manual trannies these days I'd say it's an auto.
Old May 26, 2010 | 07:02 PM
1SWT95Z's Avatar
I made 336hp/325tq at the wheels in an automatic with a 52mm tb, 218/224 .570 lift cam, pacesetter mids, hooker aerochamber, 355ci(.030 over) and 30lb injectors, 3.73s. That was about 4 years ago, so it could use another go around on the chassis dyno to see of anything has changed.
Old May 26, 2010 | 07:11 PM
SPRAYED Z's Avatar
LOL, ya its a auto and has full exhaust, stock longblock with 160kmiles.
Old May 26, 2010 | 07:18 PM
z_speedfreak's Avatar
thats pretty weak, especially for sea level.. who tuned it? any time slips?
Old May 26, 2010 | 07:22 PM
TravisMcGill2000's Avatar
Yea those number are a good 30rwhp off.
Old May 26, 2010 | 07:23 PM
1SWT95Z's Avatar
sorry, looked right over that...what a freakin idiot
Old May 26, 2010 | 07:42 PM
SPRAYED Z's Avatar
WEll it was tuned by ION. But isnt that AFR way off or is that good?
I thought it should be right around 13.5 or lower at WOT.
It ran good though even with those low numbers, it was running consistent 12.2x
Old May 26, 2010 | 10:25 PM
robsquikz28's Avatar
Damn that does seem weak as helll for a full bolt on car. That afr I think shouldve been closer to 13.4 atleast. I hope you werent spraying that.
Old May 28, 2010 | 01:19 PM
SPRAYED Z's Avatar
ANyone else, is this good or bad?
