Who has pacesetter headers with y-pipe?
Old May 27, 2010 | 07:37 PM
mdacton's Avatar
Default Who has pacesetter headers with y-pipe?
Question on these things...
installing them on someones car.....
1.steering shaft is hitting like a MF. poly mounts and umi k-member
2. y-pipe is hitting floor where it is notched on the drivers side for the chassis
3. collector is hitting on passengers side on the floor pan
Anyone else have these issues?
Have installed pacesetters like these before but always with TD never had these issues until now
Old May 27, 2010 | 07:58 PM
somlt1's Avatar
I have them you are having alot more problems than i did mine clears the steering shaft pretty well and no rubbing of the collectors, but my y-pipe does hit the body where it is notched and makes some noise
Old May 27, 2010 | 08:39 PM
Smoke Em's Avatar
for the steering shaft i grounded it down a lil bit.
as for it hitting the floor i needed to heat each header tube up and then bend them down away from the floor.
Old May 27, 2010 | 08:48 PM
robsquikz28's Avatar
Yep that always happens they suck, but you will have to bang the floorboards upward where the y pipe meets. ALso you may have to notch the headers to clear the areas where they are close.
Old May 27, 2010 | 08:54 PM
97LT1's Avatar
Mine clears steering shaft, but cuts it close on passenger side header/collector area. I will have to take a close look as I have not ran car yet. I am running poly mounts with UMI k member also. I will have to snap some pics if I get a chance.
Old May 27, 2010 | 10:23 PM
lethal bird's Avatar
i didnt have any of these problems. guess i got lucky
Old May 27, 2010 | 10:36 PM
Z28Roxy's Avatar
I didn't have to do anything to the steering shaft with mine.
Old May 27, 2010 | 11:12 PM
lt1slowz28's Avatar
my steering shaft was horrible with these headers, had to dent one of the primaries just a bit, and did a little adjusting with the 3 bolts on the firewall, inside underneath the dash/steering wheel. there's a good bit of play to it and i was able to squeeze a 1/4 inch of movement out of it.
as for the floor board vs pipe... get a hammer, a big one, and go to town.
lmk how this exhaust seals, my y pipe has been a constant pain in the *** leak after leak. but the headers were spot on.
Old May 28, 2010 | 11:59 AM
mdacton's Avatar
yeah tyhe **** leaks like a MF too.
denting **** up ansd beating the floor is not an option at all....is not my car and it is a 30k mile car orig owner etc. he isnt going to go for beating it up with a hammer.
I will figure something out, what apain in the dick
Old May 28, 2010 | 12:02 PM
00FlowCamaro's Avatar
I had no problems whatsoever. Had to remove a lot of heat shields though.
Old May 28, 2010 | 12:03 PM
meine96ws6's Avatar
mine fit with room..
Old May 28, 2010 | 12:10 PM
fex77k's Avatar
Same here.
Old May 28, 2010 | 12:11 PM
Speed Density's Avatar
hashtagBMW
My first set fit fine but that was back in 2005, this new set I have will most likely have problems because thats my luck.
Old May 28, 2010 | 01:08 PM
mdacton's Avatar
funny ive imstalled them on previous cars for people and have not had issues like these. Thought maybe it could have been k-member but its not the engine position has not moved from dtock
Old May 28, 2010 | 01:11 PM
ss.slp.ls1's Avatar
My pacesetter headers and y-pipe fit perfect. Slipped right in, nothing rubbed or hit. I have Spohn poly motor mounts. And they tuck up nice, I'm slammed and still have decent ground clearance.
Old May 28, 2010 | 01:12 PM
Maybe its just a shitt batch. Even with a k member you should have no problems like hitting the frame or even the steering shaft. But I havent installed those headers on any car since 08. So they could be makin shitty batches now.
Old May 28, 2010 | 02:01 PM
draggin97s10's Avatar
i have them with absolutley no issues. i have an ls1 steering shaft which is bigger and it still clears. hits nowhere. y pipe isnt the best fit but its ok
Old May 28, 2010 | 02:05 PM
Dadic 78's Avatar
Yeah, I'm running Pacesetter shorties too, and no problems here bolting up. Now, I can't change my plugs without removing the headers, and they come loose on the left side about once a year, but on the upside, I'm lowered 1.5" and I've got little issues with clearance.
Old May 28, 2010 | 04:20 PM
lt1slowz28's Avatar
you can shim the mount for the tranny, dropping the tail down just a bit and it makes for better clearance up front.
also, i would suggest getting a set of wide band clamps for the Y pipe as it's bound to leak.
Old May 28, 2010 | 04:23 PM
ss.slp.ls1's Avatar
That seems like it would throw off the DS angle. For most cars it won't matter much. But for hi-po hard launching cars, that -2* pinion angle (or whatever you choose to use) is important.
