SES after Header install
Old May 30, 2010 | 07:22 PM
Johnny-LT1-runner's Avatar
Rockstar
Default SES after Header install
This **** is mysterious. I am already tuned for LTs and have emissions tuned out. Today it has been running terrible, it feels like it's missing on more than one cylinder. 3 plugs had to be pulled to get the header in, so that is my first lead. I'd get the codes pulled but pepboys is the only place that does it for OBD1 around here and the Tech guy is out. So damn. Any Ideas?
Also, I tried to pull the codes like it's done on 93s but it didn't work for me.
Old May 31, 2010 | 12:12 PM
Rockstar
Anyone?
Old May 31, 2010 | 01:07 PM
Bowtie Boy's Avatar
Hard to say what it is without knowing the code. If your tuned then it shouldn't be that nor would it be running that terribly. Possibly a burned wire but I haven't heard of that throwing a code.
I thought advanced auto has a OBD2/1 Scanner main reason for saying that is they always have some extension/adapter off of the main plug on the hand held why would they have that if it was just OBD2. Dunno though.
Old May 31, 2010 | 01:14 PM
IronOutlaw's Avatar
Could be o2 sensors. Unplug the MAF and it will let the car run in open loop and see if it runs better since you cant get it scanned. When you get it scanned you will show a MAF code along with the other one but just disregard it.
Badazz 97 TA's Avatar
check your plug wires to make sure there not burned from melting on the header. common problem. Get under there and check very good.
Old May 31, 2010 | 01:20 PM
01ssreda4's Avatar
I have some spare plugs wires if you need them. I'm pretty sure the wires are routed away from the primaries
Old May 31, 2010 | 03:07 PM
Rockstar
Alright, I had some time to go by advanced and tried to have the codes pulled and I got nothing. The SES light will not flash any codes.
I have already checked all plug wires and they're all good. I was thinking O2's because they are the 16 year old originals. I'll try the open loop thing.
Old May 31, 2010 | 03:29 PM
defaultexistence's Avatar
new o2's ftw! ac/delcos only!! new 02's are a must with new headers IMO! solved my shitty running motor after lt's......
Old Jun 1, 2010 | 02:04 PM
Rockstar
Put some new O2s in this morning and now it runs great. Problem solved.
