GM847 + home ported heads dyno results
First of all congrats on the numbers!
That said, I'm just happy my baby cam and stock heads makes the same peak tq you do and more everywhere else in the curve.
Now, get a set of mean ported heads on it (AI 200's come to mind) a little juice to make up for the loss down low and that car will probably RAPE in the 1/4, assuming it hooks good![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Just guessing, but if mine was an M6 also, it would be making 10-15 more rwtq... as well as rwhp?
Again, I'm not worried about the "loss down low"... that's what my converter is for!
Couple more things...
Are you talking about spinning?
Why are you taking off at 2000 rpms?
I just think it goes to show what these guys are talking about, all the HP in the world doesnt do you any good 1) if it's in a small rpm window and 2) if you can't put it to the ground.
On the street, I jump them out of the hole because I make 330ft lbs at 2000 RPMS and the tq climbs from there and the car never quits pulling.
