Engine bay is done! A few issues with first startup...
Old Jun 1, 2010 | 01:39 PM
Formula383's Avatar
Originally Posted by whytryz28
Weird...
Hey what opti you running on that thing?
Dynaspark
Old Jun 1, 2010 | 01:40 PM
whytryz28's Avatar
Originally Posted by Formula383
Dynaspark
Is that like the Delphi optis? Im replacing mine with an ac delco one, which would be the best choice?
Old Jun 1, 2010 | 01:49 PM
Formula383's Avatar
It all works the same. The dynaspark is made much better but is also more expensive. Take a minute and read up on their site.
http://www.dynaspark.net/advantage/
After receiving mine and seeing the quality put into the dynaspark, I would not hesitate to get another one if needed. I know of a few high horsepower LT1's with this unit and they have had zero issues.
Old Jun 1, 2010 | 02:03 PM
jay7199's Avatar
Old Jun 1, 2010 | 02:14 PM
I8ASaleen's Avatar
I would have to agree with everyone else on the #8 pigtail issue because if you swapped the injectors out and the issue remained it must be the wiring.
Old Jun 1, 2010 | 03:30 PM
12345678910's Avatar
i had that problem on a sbc had to readjust the valves
Old Jun 1, 2010 | 03:36 PM
Formula383's Avatar
I was inclined to think that at first also, however I had the same problem on a different set of heads, cam and intake last fall. So 2 different combos with the same problem makes me think it's something external to the engine.
Old Jun 2, 2010 | 08:30 AM
Formula383's Avatar
Changed the injector pigtails on #2 and #8 last night. The #8 primary is still getting extremely hot after only a few minutes at idle. I will pull the spark plug out today. It was too hot to get to last night.
Old Jun 2, 2010 | 09:31 AM
FASTFATBOY's Avatar
Originally Posted by JB_97ws6TA
as far as the glowing primary is concerned the only thing that i can think of off hand is injector related. LT1 pcms cannot tune individual cylinders so if it is only one primary on one bank than I would check injector pulse with a noid light and if that checked out than perhaps I would consider swapping that injector with another on the same bank and see if the problem follows the injector or stays with the cylinder. I wouldn't run the car very long until you get that panned out, if it is running that lean to get a glowing primary without any real load than you could potentially do some serious damage. Good luck
According to Ed Wright LT1 ecms CAN in fact tune individual cylinders.
I would look at that injector ASAP. I would not run the car until I figured that out.
And FYI Single planes are notorius for corner cylinders being lean, it has to be corrected with porting.
My car has hurt #8 two times now. I had the intake ported this time.
Old Jun 2, 2010 | 09:46 AM
Formula383's Avatar
Yeah, I think you're right (and Ed of course). I found the "Individual Cylinder Fuel Trim Multiplier" table in CATS Tuner for tuning the cylinders but everything in that table appears to be normal. I tried swapping #1 and #8 injectors but #8 was still a problem. So I don't think it's an injector problem. After talking with LE this morning, I may have a weak spark to #8 which is causing fuel to be burned in the primary instead of in the combustion chamber. I plan on picking up some plug wires this afternoon and trying again. #8 is hard to get to and I very well may have damaged the wire taking it off/on and it's the one thing that has remained the same across builds.
Thanks for the suggestions. I will let you know what I find.
Old Jun 2, 2010 | 10:49 AM
MasterTomos's Avatar
engine bay/intake=
that's how the air intakes should have been from the factory! bastards!
lookin good tho!
Old Jun 2, 2010 | 01:05 PM
  #32
Fondle's Avatar
Fixed!!
Yeah, somewhere during the time I was at A&M, they changed from GPA to GPR. I still don't understand it...
I found the problem. You should have gone to a real school, like UT or something
Jk car looks great cant wait to see out it again, hopefully you get your problem fixed
Old Jun 2, 2010 | 01:28 PM
  #33
Tony Shepherd's Avatar
Lloyd Elliot gets the cookie! It was the plug wire. Kyle will chyme in shortly.
Old Jun 2, 2010 | 01:54 PM
  #34
BLK,97,T/A,M-6's Avatar
happy to hear thats fixed... now lets see some video!
Old Jun 2, 2010 | 05:49 PM
  #35
Verz's Avatar
Agreed
Old Jun 2, 2010 | 07:05 PM
  #36
Formula383's Avatar
#8 read around 150K ohms! 6 wires read around 500 ohms and #3 read around 2K ohms so it was probably on it's way out too. I picked up a set of new wires and got them installed. Fuel pressure looks to be a few PSI low but the primary isn't glowing anymore.
Thanks LE!
Vid!!
http://www.youtube.com/watch?v=vmJVbj26r4s
Old Jun 2, 2010 | 07:22 PM
  #37
gregrob's Avatar
Hump worthy
Old Jun 2, 2010 | 08:13 PM
  #38
flyinZ's Avatar
Looks yummy! Sounds great, man.
Old Jun 3, 2010 | 03:54 PM
  #39
JAKEJR's Avatar
Wow, one letter out of 147 words and my spelling sucks. Damn, guess my 3.98 GPR in college wasn't enough for the interwebs.
No need to defend that error. None of us is "prefect". LOL
Jake
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
Old Jun 3, 2010 | 04:49 PM
  #40
Tapout911's Avatar
Was really hoping you wouldnt figure out the problem. Cars get real cheap in moments of frustration and I was willing to come take it off you hands lol. Sounds and looks great as always. Wish I had your patience
