Engine bay is done! A few issues with first startup...
Moe is going to try to meet me tomorrow or Thursday to see if we can get the tune ironed out. I'm going to do a little more research on why the primary is getting so hot. Any suggestions from you guys would be great. Here's a few pics of the finished product with the custom intake tube and upper radiator support.
I'm curious about that radiator support. What's going on under that panel? What kind of filter are you running? Is the intake pipe steel or aluminum?
Thanks
The car has not seen any load yet. Maybe only 5-10 total minutes of idle time in the garage over the last few days.
Good luck on that #8 issue, have you pulled the plug to look at it?
What noid light do you have? They are pretty easy to use. It should have a pretty strong pulse at the light for a good signal. You can also get a multimeter on it.
and wtf is a GPR?
