HOw do I make a solid lifter?
Old Jun 2, 2010 | 09:51 PM
SPRAYED Z's Avatar
Default HOw do I make a solid lifter?
OUt of a hyd. lifter? Can someone show me how to do it?
thanks, Tom
Old Jun 2, 2010 | 09:57 PM
fleetmgr's Avatar
You don't. You buy them that way.
Old Jun 2, 2010 | 10:00 PM
RamAir95TA's Avatar
thanks, Tom
Hopefully you're doing this only to mock up proper pushrod length...
Remove the snap-ring and pull out the plunger. Replace the plunger with a piece of all-thread, bar stock, etc. (or similar). You will need to cut the piece to length until you can just barely get the snap ring back installed.
Essentially, you're replacing the mechanical hydraulic portion of the lifter with an immovable object.
Old Jun 2, 2010 | 10:26 PM
SPRAYED Z's Avatar
Thats all I need it for ANd to check PTVC
Can I just put a bolt in there or something else, I dont have that where im at.
Old Jun 2, 2010 | 11:31 PM
RamAir95TA's Avatar
You can use anything you want...like I said, "or similar."
Old Jun 2, 2010 | 11:33 PM
gregrob's Avatar
Stack small washers in it. Works pretty good
Old Jun 3, 2010 | 12:05 AM
robsquikz28's Avatar
I used a bolt and I use it all the time
Old Jun 3, 2010 | 10:40 AM
SPRAYED Z's Avatar
got it thanks
