Post Up Your Single Plane PICS!
Nick
With the correct setup, correct intake porting and cam, 20-30hp over a maxed out stocker.
The build has to start from ground zero IMO with this in mind. Alot of the results that have been posted with this swap were stock intake setups that did this swap and didnt pick up much, most all were unported.
Been too long since I bought it all..........It was all bought brand new initially.
Super Victor#2925, Summit $225 I think
Conversion to EFI, including the elbow that Puck has now by intakeelbows.com$ No idea $450 comes to mind. That included fuel rails.
Monoblade, Formula 383 has it now, Caught it on sale $450
Assorted AN fittings, who knows...$150 easy
I have changed it since the initial deal, sold the elbow and monoblade.
Bought a Holley 4 hole 4150 billet throttlebody for $100 used
needed and IAC $35
Spectre carb hat, Jegs $78 shipped.
45* 4 inch elbow $45 at truck shop
4 inch Maf hose, free from my machinist
Sent the intake to Bret Bauer for porting, including shipping and fitted 1 inch spacer $450
Had a huge K&N already, assorted 4 inch bends left over to get the filter on.
Was it worth it? I can tell you this, I havent run the car yet. Ed Wright has been tuning the car via e mail and datalogs with me reporting a/f ratio.
He is getting closer a/f is 12.8 to 13.1 on his last shot.
It was 95* degrees out, I pulled it into 1st gear rolling 30-35 mph.....put it on the mat and with 325 50 drag radials this turd DESTROYED the tires through 2nd gear and a tad of 3rd. Car has never done that in this kind of heat. DId it on 2 different streets.
To me the single plane was worth it.
needed and IAC $35
Here are my pics, cant remember all the prices but it was expensive.
Procharger (Tallboy) carb hat $210.00
Fast T/B $550.00
Nitous Cheater plate & solenoids swap meet $110
Powder coating $75
Victor E
Aeromotive fuel regulator
Mallory distributor drive w/steel gear
Homemade pipe from mass air to hat
Suncoast creations ram air box for predator hood
Jegs nitrous solenoid brackets
Close to having it running again to get some track time before shootout!
Fast T/B $550.00
Powder coating $75
Victor E
You need to get a bigger hat on that thing, with as low as yours is you can get a hat like mine on it, granted you will have to notch the rear of the hood and cowl but it will fit. Mine was within an inch of fitting, yours would I am pretty sure. I am a good bit higher than you at the throttlebody.
I had a Suncoast ram air hood on mine that looked JUST like yours see the sig pic.
needed and IAC $35
Stay away from those edelbrock elbows, they suck.
Really diggin slow95's set up, wish I was back in the states already... hard to piece everything together from abroad.
back from the dead!
Also if anyone is doing this conversion and wants to use an elbow I have a new Nitrous Outlet 860 elbow for sale.
http://i1110.photobucket.com/albums/...1Engine019.jpg
http://i1110.photobucket.com/albums/...1Engine020.jpg
http://i1110.photobucket.com/albums/...1Engine023.jpg
http://i1110.photobucket.com/albums/...1Engine022.jpg
