Post Up Your Single Plane PICS!
Old Sep 23, 2013 | 06:34 PM
  #101
Vicious95Z28's Avatar
What's up guys? Who's still doing the single plane conversions?
Old Oct 16, 2013 | 08:47 PM
  #102
NufNuffZ28's Avatar
Very nice setups in here.
Anyone have an elbow(tpi or lt1 style) or SBC efi single plane for my Iroc???
Old Oct 17, 2013 | 05:20 PM
  #103
Wildcobra's Avatar
Any more 4150 set ups
Old Oct 17, 2013 | 07:25 PM
  #104
BIGCAT7274's Avatar
Old Oct 17, 2013 | 09:50 PM
  #105
Puck's Avatar
Love those valve covers.
That your current motor or a new build?
Old Oct 18, 2013 | 03:02 AM
  #106
BIGCAT7274's Avatar
Current.
Old Oct 18, 2013 | 10:03 PM
  #107
Ponyhntr's Avatar
From my ongoing build thread....
https://ls1tech.com/forums/lt1-lt4-m...-2013-lol.html
Old Oct 21, 2013 | 11:00 PM
  #108
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
Wilson Manifolds will do lt1-sbc bolt hole head conversion for $200. if you call and speak with Dave Secunda, tell him i said hello! they were super prompt and also did my new manifold in basically 2 weeks. simply badass! their workmanship is second to none!!!! if you want your manifold done.... then get ready to dig deep, depending if you get the supreme deluxe pizza or just the cheese pizza, lol! either way you'll dig deep. best money i have spent on the car. especially when the motor made 725 on the dyno!
Old Oct 22, 2013 | 12:27 AM
  #109
Rob94hawk's Avatar
Originally Posted by BIGCAT7274
Damn that's nice. That looks like it would actually fit under my Firehawk hood without any modification.
Old Oct 22, 2013 | 05:23 AM
  #110
BIGCAT7274's Avatar
It probably would now that I flipped it upside down.
Old Oct 22, 2013 | 02:24 PM
  #111
Rob94hawk's Avatar
Where are the fittings for the MAP sensor and all the other crap that goes on a stock intake manifold?
Old Oct 22, 2013 | 02:32 PM
  #112
Ponyhntr's Avatar
On mine I have fittings drilled and tapped into the base of the elbow.
Old Oct 22, 2013 | 02:50 PM
  #113
BIGCAT7274's Avatar
The back of my eldow has 3 ports that can be tapped. I am making a block for my 3 bar map sensor. When it dies i will swap it for a threaded map sensor.
Old Oct 22, 2013 | 04:13 PM
  #114
Puck's Avatar
My Accel TB has a few threaded ports in the back to mount barbs for vacuum ports.
Old Oct 22, 2013 | 05:09 PM
  #115
FASTFATBOY's Avatar
Puck, dont you have my old elbow? Someone in here does.
I drilled and tapped the back of the elbow where Aaron put a plate and screwed every vacuum port the intake had into them.
When I changed to a 4 hole throttle body I had to have a spacer for the throttle linkage to clear the fuel rail.
I got a vacuum tree off the underside of a 87-93 5.0 Mustang upper intake and drilled and tapped the spacer to fit it.
Search my name and you will find pics.
EDIT, read this thread for my MAP sensor solution.
Old Oct 22, 2013 | 05:29 PM
  #116
Puck's Avatar
Yea I did for a while, killer piece...sold it before even running it though. I am just a tiny bit undecided - went from ported LT1 intake+AS&M 58mm, to Supervic w/ 860 performance elbow, to Supervic with your Intakeelbows.com piece, to an Accel/DFI 4bbl all without ever running any of them .
I think Ponyhntr has it now?
