93 camaro code 42
Old Jun 9, 2010 | 10:58 PM
old93camaro's Avatar
Default 93 camaro code 42
I'm getting a code 42 after engine install but the car starts....sooooo would this be a bad coil, crossed ground or the ICM thanks for your help up front. Oh yea i tried the search
Old Jun 10, 2010 | 08:22 AM
morning bump for day crew
Old Jun 10, 2010 | 10:50 AM
whytryz28's Avatar
This is the code. Not sure what it means though.
42 The EST circuit voltage was below 0.5 volts when engine speed was below 3000 RPM.
Take the coil off and test it with a multimeter
Old Jun 10, 2010 | 01:28 PM
yea im going to try that today also will a ground not being in the right place cause this, because i put the ground on the engine block instead of on the coil...
