crank hub sleeve
Old Jun 10, 2010 | 10:36 PM
95BlkBird's Avatar
Default crank hub sleeve
I'm going to be installing a sleeve on the crank hub tomorrow and need some ideas how to put it on. I don't have access to a press so gotta go a different route. Friend told me to place the hub in the freezer and the sleeve in the oven. His theory is the hub will shrink and sleeve expand making it easier to install. Makes sense but sounds too easy lol. Any ideas?
Old Jun 10, 2010 | 10:44 PM
fleetmgr's Avatar
Freezer/oven will work great. And yes, it's that easy.
Old Jun 10, 2010 | 10:50 PM
95BlkBird's Avatar
what should I put the oven on and for how long?
Old Jun 11, 2010 | 05:47 AM
fleetmgr's Avatar
I'd try 250 for 30 minutes or so.
Old Jun 11, 2010 | 03:10 PM
jaycenk's Avatar
Cooked to a nice golden brown lol.
Old Jun 11, 2010 | 03:23 PM
blackz93's Avatar
What is a hub sleeve?
Old Jun 11, 2010 | 03:42 PM
95BlkBird's Avatar
Old Jun 13, 2010 | 10:40 AM
blackz93's Avatar
Hmmm... what's it for? Never seen one before!
Old Jun 13, 2010 | 11:00 AM
IronOutlaw's Avatar
I believe they are for sealing oil leaks at the crank hub. A little groove eventually wears into it causing it not to seal. I'm putting one on my car.
Old Jun 13, 2010 | 11:01 AM
fleetmgr's Avatar
Correct, they are to repair the little groove that forms. Prevents have to replace the hub.
Old Jun 13, 2010 | 11:37 AM
95BlkBird's Avatar
Was extremely easy to install. I put the hub in the freezer for 20 mins and put the sleeve in the oven @ 250 for 20 mins. Pulled both out and installed in seconds. After installing when you pull the flange off make sure there are no burs or it will slice the seal. Other than that easiest thing I have done so far lol.
