window motor how well does this work
Old Jun 13, 2010 | 11:14 PM
SPEED#1's Avatar
Default window motor how well does this work
http://shbox.com/page/windowmotor.html
How can I tell where to drill holes in my door and properly reach the rivets on the window motor?
Also what holds the regulator from going crazy after the motor is out?
isnt it spring loaded, so when I take out the motor what will happen?
Is there anything else to beware of or to make things easier.
List of things needed?
thanks guys
Old Jun 13, 2010 | 11:41 PM
RamAir95TA's Avatar
thanks guys
Uhh...not to be an ***, but did you even look at any of the pictures?
Old Jun 14, 2010 | 07:36 AM
stryker1320's Avatar
X2. I followed those instructions to the letter when I did mine and had no problems. And no, nothing is spring loaded in there. Just read through that page completely a couple more times and it will become more clear when you tear into it.
Old Jun 14, 2010 | 07:56 AM
letsrun97z's Avatar
I drilled mine by sight and feel wasn't that hard to do I think I did both under an hour
Old Jun 14, 2010 | 08:25 AM
shbox's Avatar
Apparently not.
Old Jun 15, 2010 | 11:04 PM
SPEED#1's Avatar
I didnt but thanks I see it looks stupid proof thanks guys
Old Jun 16, 2010 | 12:38 AM
SS RRR's Avatar
Village Troll
I used a 1/2" hole saw. Made getting the nuts threaded far easier.
Old Jun 16, 2010 | 07:52 AM
shbox's Avatar
In my recent RH motor replacement, I used a conical grinding bit in the Dremel. Other than the dust, it worked well. Nice, smooth hole.
Old Jun 16, 2010 | 08:10 AM
TheTransporter69's Avatar
i used that guide it worked great, make sure you clamp the window up so it doesn't fall when u pull the window motor out.
