List of stuff needed for installing headers
Old Jun 17, 2010 | 10:27 AM
nascarextreme's Avatar
Originally Posted by 1993 z28 f1
If you have an oil cooler you will need, to shorten or get two shorter bolts to fit the filter spin on inplace, I just shortened mine with the grinder. you also have to plug the lines @ the cooler/ radiator if you dont want a few oil drips on the headers.
What did you use to plug the lines? Are they rubber hoses or what?
Old Jun 17, 2010 | 08:14 PM
1993 z28 f1's Avatar
Hey:
They came in a pkg of about 10 Rubber covers from autozone, about 5 different sizes, approx 1/2", two needed, not much else, you can remove the rest.
Dub
WhenIn Doubt Do Without
Old Jun 21, 2010 | 10:36 AM
Bump... Anyone have anything else to add?
Old Jun 21, 2010 | 08:34 PM
Hey:
Get at least 1 or 2 buddies to help you and be careful to wipe/clean all the fingerprints off the headers before you start it or they will have permanent imprints in the headers once they get hot.
Dub
When In Doubt Do Without
Old Jun 21, 2010 | 09:40 PM
^cool! Good to know. Any other tips are definitely welcomed!
Old Jul 6, 2010 | 04:58 PM
Since I'm not real sure on weather I got the answer or not... What will I need when it comes to 02 extensions? 1 or 2? how long? etc.
Old Jul 7, 2010 | 12:15 PM
I forgot to say that the car is a 1994. Oops!
Old Jul 7, 2010 | 03:40 PM
Hey:
From post #17 item 1,
1 ea. 12" o2 ext for 94-97 pass side, is all I needed for my LPP headers.
How is the install coming?
Dub
Old Jul 7, 2010 | 03:45 PM
Thanks, I wasn't sure if "1 ea" meant 1 for each, or 1 total.
I haven't started the install yet, but the headers and y pipe are here now. I just have some odds and ends on my list of things to get before I start the install. I will probably do them sometime early next month or something like that.
Old Jul 7, 2010 | 04:48 PM
Hey:
Good luck on the install.
Dub
Old Jul 7, 2010 | 10:31 PM
I also am wondering. Do the lines that I am capping let oil flow through them or coolant? Are they under pressure? If so, how will just capping them off work if they are under pressure?
Thanks for putting up with my noob questions!
Old Jul 8, 2010 | 06:43 PM
  #32
Hey:
Oil and no pressure you are removing all of it.
The caps are plugging the holes left that oil was in so it does not blow all up under your car. You put the oil filter spin on,back on after getting shorter bolts back in place of the oil cooler, then you are done after removing the oil level sensor in the pan, just ty wrap it up out of the way. You also need to heat shield or heat wrap the fuel lines .
Dub
Attached Thumbnails List of stuff needed for installing headers-dsc0052711.jpg
Old Jul 8, 2010 | 10:52 PM
  #33
Thank you for all of your help! What exactly am I looking at in that picture though? I don't have to leave the oil level sensor out of the pan do I?
Old Jul 9, 2010 | 11:28 AM
  #34
Hey:
The pic is how close the fuel lines come near the ORY.
The sensor may be able to stay in the pan, but the connection has to be removed as it will be melted if left in place, you will know better after you get started on it.
Dub
