what head gakets to use for this build
Old Jun 20, 2010 | 11:43 AM
aug181983's Avatar
Default what head gakets to use for this build
Its a 383 with forged flat tops and I will be running Le3 heads. This car will have nitrous atleast a 200 shot. Which head gasket will be best for this setup.
the pistons are zero decked in the hole
pistons are mahle sbc125030f05
dome volume is -5cc
c/r is a 11.1 with what gasket to achieve that number ?
236/240 .592/.592 cam specs
Le3 heads 57cc
4.030, 3.75 stroke and a 6" rod hope this helps everyone
im looking into a impala head gasket for my build will that work for my build
thanks guys
Old Jun 20, 2010 | 12:19 PM
mark97ta's Avatar
you can look around and find a cr calculator and figure out what thickness to get you your ideal ratio... as far quality gaskets go, every one will have their own opinions... I have cometic mls gaskets... they seem to leak just a tad on the back of the motor but they are holding 15-16 psi of boost with no problems so far
Old Jun 20, 2010 | 08:30 PM
SPEED#1's Avatar
mr gasket or felpro
I see many people using that 5716 mr gasket one! that one might work for you
Old Jun 22, 2010 | 10:16 PM
aug181983's Avatar
back up.....
Old Jun 23, 2010 | 07:57 AM
FASTFATBOY's Avatar
If the block is "zero decked" the pistons are not "in the hole", they are flush with the top of the block. Mistake if you want 11 to 1.
To get a 10.98 to 1 you will need......
Fel pro 1074 gasket, .039 compressed.
-13cc reverse dome piston.(Wiseco makes a set)
The above are the most common parts off the shelf.
Or have a custom head gasket made by Cometic, .075 thick
You got problems. Right now you are at 12.1 to 1 with a Fel Pro 1074 gasket that is .039 thick.
Old Jun 23, 2010 | 09:04 AM
SPEED#1's Avatar
Nah that part number shows it being 11.1 with those pistons and whatever they use for heads...OP just wants a gasket.... I remember this thread before but it was different. IF you want to use the impala gasket go ahead or the felpro 1074, both willl suffice.
Old Jun 23, 2010 | 11:00 AM
draggin97s10's Avatar
what cc are the LE3s. how far are the slugs in the jugs? need some info my nizzle
Old Jun 23, 2010 | 11:16 AM
robsquikz28's Avatar
it says they are 57cc
Old Jun 23, 2010 | 11:29 AM
FASTFATBOY's Avatar
Was I the only one who read his first post? Are the only one who DIDNT?
Old Jun 23, 2010 | 01:09 PM
actually yes i completely missed that. i kinda automatically assumed that if you had all that info you could find a CR calculator and figure it out yourself. thats what i get for assuming huh?
