having problems with brand new msd opti
Old Jun 22, 2010 | 10:57 AM
ElkySS's Avatar
Default having problems with brand new msd opti
had been on the car 2 days then went to the track. as soon as i run, this starts happening:
when im at wot and about 6k, it misses so bad the tach wont move. its been very on and off. under any other circumstance, it runs great. i called msd and they said if its not throwing a code for high ir low resolution, its not the opti.
any thoughts?
Old Jun 22, 2010 | 11:16 AM
ElkySS's Avatar
i also put silicon around where the wires go into the opti and a thin bead around the cap to seal it to the base
Old Jun 22, 2010 | 11:26 AM
93FireBirD's Avatar
hows the coil? Are you sure its not something else?
Old Jun 22, 2010 | 11:34 AM
ElkySS's Avatar
idk thats why im posting a thread. i kinda thought the timing may have been off when they made it so i asked msd how to set it back to factory settings. havent driven it since that yet. was kinda thinkin coil. its an msd blaster, been on there for
a year or 2, i guess. it does seem to get worse when its been running for a while
Old Jun 23, 2010 | 08:21 AM
ElkySS's Avatar
anyone else?
Old Jun 23, 2010 | 09:25 AM
defaultexistence's Avatar
check coil , check icm at your local parts store replace if needed, say fuckit and go efi24x
Old Jun 23, 2010 | 09:40 AM
ElkySS's Avatar
icm is new but i got a spare so i guess ill swap it. i wish i could use the efi system. kinda broke at the moment tho. plus i have a double roller so idk how thats gonna work
Old Jun 23, 2010 | 11:56 AM
brettmc's Avatar
my coil and icm passed the tests on shbox's website but I replaced both anyway and that fixed my no-run problem.
Old Jun 23, 2010 | 01:36 PM
BALLSS's Avatar
any thoughts?
assumeing your issue is not valve float....my MSD did crap at high RPM's also. MSD replaced it and I sold it. My original OEM opti solved the problem and is still on the 383
Old Jun 23, 2010 | 02:24 PM
94Z28rag's Avatar
I stayed away from the MSD optis because of hundreds of stories like this. Cut your losses and get a new GM opti from Summit.
Old Jun 23, 2010 | 03:52 PM
MasterTomos's Avatar
Funny there was a thread on here not too long ago and I got ripped on by one or two people for saying this...
Old Jun 23, 2010 | 04:42 PM
mark97ta's Avatar
i am not familiar with these opti's but don't they have a timing adjustment... have you tired to play with that and see if it changes... could also be valve float... what plugs and their gap ?
Old Jun 23, 2010 | 04:58 PM
ElkySS's Avatar
update: looks like i fixed the problem. i replaced the icm and reapplied the di electric grease. drove home wot the whole way, didnt miss once and ran real strong. wont no for sure till i drive it for a little while but this is the longest its gone without missing since the opti went on. if it does it again, im warrantying the msd and getting a delco. (which i have had)
Old Jun 23, 2010 | 10:14 PM
robsquikz28's Avatar
update....
