Quick !AIR Question
Old Jun 23, 2010 | 02:23 AM
xKellyxVeitx's Avatar
Default Quick !AIR Question
What can I use to plug the holes in the stock exhaust manifolds?
Old Jun 23, 2010 | 06:24 AM
SSweet97's Avatar
Do a search on "Block Off Plates". I'm quite sure you will find an answer. Also, post your question on Camaro Z28.com if you don't find out on this forum, but I'm sure you will find your answer in this forum.
Old Jun 23, 2010 | 09:18 AM
defaultexistence's Avatar
Kelly ,find some threaded pipe plugs from a hardware store ,usually have a square head on em' to be tightened with an adjustable wrench,Also ebay is your best source for so much as you begin your install/modding. look for egr block offs,pumps,...alll kinds of stuff there . ~Michael~
Old Jun 23, 2010 | 09:20 AM
MasterTomos's Avatar
just did bolts in mine and had them welded
Old Jun 23, 2010 | 11:16 AM
Low N Slow's Avatar
Try an M22 oil drain plug
Old Jun 23, 2010 | 11:24 AM
RamAir95TA's Avatar
OBDI cars use an M22 plug, OBDII cars use an M18 plug.
Old Jun 23, 2010 | 01:27 PM
Originally Posted by ramair95ta
obdi cars use an m22 plug, obdii cars use an m18 plug.
drain plugs ftw!! Dude!!!! Lol
Old Jun 24, 2010 | 09:14 PM
Is this rule absolute? My motor was thought to be 1997, but the M18 was too tiny.
Old Jun 24, 2010 | 09:43 PM
RamAir95TA's Avatar
Hopefully I don't have it backwards. Try the M22.
Old Jun 24, 2010 | 09:44 PM
Oh my.
