gears or spray?
Old Jun 25, 2010 | 10:59 AM
93TAJ.C.'s Avatar
Default gears or spray?
hey guys i cant decide between gears or spray, i was set on gears but have heard that going from 3.23's to 3.73's wont be worth much. But i don't want to spend all the money for spray just to risk blowing a good lt1.
So will the gears be worth much in my bolt on m29 t56 trans am?
How much spray can i run without worrying about flaming death?
If i do go with gears i will just buy some good used gm gears and an install kit with all new bearings. I work at autozone and my boss will do my gears for free. So it's 275 for gears or who knows what for spray.
Old Jun 25, 2010 | 11:52 AM
BlackBird87's Avatar
If your boss knows what hes doing and i mean realllly knows what hes doing then go with gears first. In your case its a minimal investment whereas doing spray the right way can get pretty costly
Old Jun 25, 2010 | 12:01 PM
SPEED#1's Avatar
Nitrous all the way!!!!!!!!!!!!!!!!!!
Old Jun 25, 2010 | 12:31 PM
93TAJ.C.'s Avatar
will gears be a good gain?
Old Jun 25, 2010 | 01:08 PM
pyro719's Avatar
Spray it!
Old Jun 25, 2010 | 01:12 PM
93TAJ.C.'s Avatar
lol i was at a party across the street from you a while ago pyro. But still, i know i want to spray it, but will gears be a good step? sotp gain?
Old Jun 25, 2010 | 01:18 PM
LTXBOI's Avatar
if you have a m6 why not go 410 gears you will notice a night and day difference! I would do gears first break them in, then look forward to the spray
Old Jun 25, 2010 | 01:32 PM
litch2004's Avatar
He has a M29. Going 3.83 is the same as going 4.10 in the M26 due to the gearing difference in the '93 M29.
Old Jun 25, 2010 | 01:41 PM
pyro719's Avatar
Why not do both? N20 will make way bigger difference though.
Old Jun 25, 2010 | 02:40 PM
gregrob's Avatar
Spray is way more spend, especially considering you'll need a clutch if you plan to hit it with a decent shot
Old Jun 25, 2010 | 03:27 PM
You will gain more with spray for sure
Old Jun 25, 2010 | 03:32 PM
T/ALT1's Avatar
Definately spray. Don't waste your money on gears now.
Old Jun 25, 2010 | 03:40 PM
I8ASaleen's Avatar
If you're going to do gears I would save up and get an entire rear all at once instead of invest in the 10-bolt. This would be a wiser decision if you have higher power goals. Spray will end up costing you more in the long run b/c of the refills, safety equip, new clutch, better ignition components, etc...
Old Jun 25, 2010 | 06:38 PM
93TAJ.C.'s Avatar
ok i shouldent have asked about spray lol. I have the m29, not the m28, so the 3.73's will be what i'm gunna run. just wanted to make sure they are worth the 275 i'll have to shell out. I still want to do spray, but kinda have made up my mind that gears are where the line is being drawn right now because i know i'll have to get a clutch, dr's etc.
So here is the question.
Will i feel a good gain from 3.23's to 3.73's?
i really feel that it'll help alot off the line wich is where i need it, 2nd and 3rd pull strong, and maby 4th could use a little help too. I dont see this car going too much further. I still want a cam and spray with supporting mods, but dont think i'll get into the heads or block as much as i wish i could, and if i do it wont be for quite a while as my wife is prego lol, funny how that changes things lol.
Old Jun 25, 2010 | 06:52 PM
mrchyzy16's Avatar
are you running a cut-out or straight pipes? I wasnt sure cause i dont see it in your sig. If not then maybe a cut-out could also be a consideration. I know you only asked gears or spray but i figured i would put my 2 cents in.
Old Jun 25, 2010 | 06:53 PM
93TAJ.C.'s Avatar
It's lt's through 3"ory and a dumped moroso spiral flow. sounds like sex. Stasy on topic! lol
Old Jun 25, 2010 | 09:15 PM
kierstyn's Avatar
Spray that thing dont waste your money on the 10bolt!
Old Jun 25, 2010 | 10:48 PM
You'll be able to feel a difference. do you like the derlin **** i was looking into them and dont yell at me for getting off topic hahaha
Old Jun 25, 2010 | 11:30 PM
93TAJ.C.'s Avatar
yeah i got the straight long ****, its pretty nice, hitting 3rd is waaaay better since i got it. I have two, I'll sell you one if you would like
Old Jun 26, 2010 | 12:17 AM
93TAJ.C.'s Avatar
what kind of shot would be ok for a bolt on lt1? how often can i use it?
