ebay valve spring kit
#43
other than the pro mags what rockers are you guys running with these, I had a hot cam spring fail so I figured I'd give these a shot and the 1.6 gm rr won't work, the tip of the rocker outside the roller tip touches the retainer, so now I need a different rocker... The promags sure look good.
#44
TTT
any updates from you guys running these springs? i'm about to buy a set and don't want to waste my money...are they worth it? I see that speedy has had success, anyone else want to jump in?
#45
I have 1800 miles on these springs with no problems so far. I didn't get the dual spring but went with the singles since my cam is a cc305 copy. I wouldnt have a problem recommending these springs to other people on a budget.
#49
lunati also sells a economical spring also
i think these would work good..
http://www.jegs.com/i/Lunati/638/73943/10002/-1
#50
LS1TECH Sponsor
Those Lunati springs show 108 lbs of seat pressure at 1.750". Stock set up ht is 1.780" or so and that spring would have about 100 lbs at that ht. It would be comaprable top a Hot cam spring ons not really a good choice for anythuing other than a Hot Cam ot stock LT1 cam.
You would want something with atleast 130 lbs of seat pressure and preferably 145 lbs or so.
Lloyd
Lloyd
#52
Lloyd
Lloyd
#53
buddys had these on and has about 4000 miles on them, it was a stock rebuild with the 492/492 hotcam and used these springs. ive been with him when hes ran the thing to 6000 in a few gears haha! im ordering a few sets this weekend 2 for current builds and one to put on the shelf for when the third motor goes together
#54
Though I can not 100% say these are the springs in my car, they do look the same, mine have a blue stripe on the inside spring and I think I see that in the pic posted but I am not sure, the car I have has had the sht beat out of it for a while now (6-10k miles, I have put 4k on them and however many miles the previous owner did), I know there is a cam in here and LE2 copy heads, I shift at 6200 in 1st and 2nd and 6000k in 3rd no issues what so ever, well I take that back, I have 1 rocker arm that the nut keeps backing off, and I have to pop the valve cover off ever 1k miles or so..but I do not know if it has anything to do with the springs.
