Pictures of my year long overhaul
Old Nov 28, 2010 | 07:23 PM
  #81
flyinZ's Avatar
Check gauge light wont be on b/c the oil pressure is too high, cold mine will go that high. That light may have something to do with, why it wont go into gear while running, or its another problem.
Will it go into gear at all?
Old Nov 28, 2010 | 07:39 PM
  #82
LarsV8's Avatar
Well I had the oil pressure sensor and low oil sensor backwards, when I fixed it, thats when the check gauges light came on, so I dunno, I assumed it was because oil pressure was high.
With the tranny, the car will go into gear when it is off, but will not when the car is running. When I try to put the car into gear it will start to move the car forward and then kill the motor. I picked up a mity vac from autozone and used a method that someone made a writeup for on this forum, but still had no luck.
Old Nov 28, 2010 | 08:48 PM
  #83
bufmatmuslepants's Avatar
Awesome build . After college I had the choice of either rebuild the camaro, or buy a house, and I bought a stupid POS house which is stealing all of my god damn hard earned money. Do the fuel line mod while you are in there (free), its a shame that beautiful motor is hidden by that big ugly hose. Get a scanner, read the code and find out what the SES is. As for the trans, drain the fluid, refill it to the proper level.
Old Dec 15, 2010 | 01:31 AM
  #84
LarsV8's Avatar
So I ended up taking the car to the tranny shop, since I don't have room to drop a tranny. The problem ended up being a bad clutch fork. Fixed and finally got to drive her! She rides very rough, probably because of the poly motor mounts and open headers. I will get a video up this weekend!
In the meantime, more goodies in the mail:
Things left to do:
-Find out why the oil pressure is so high
-fix oil leak at low pressure sensor
-reroute and shorten spark plug wires
-find a more permanent solution to the caps (I need a breather)
-paint the engine pay
-add some wire looms
-install y-pipe
-get insurance
-get inspection
-get registration
-DYNO TUNE
Old Dec 15, 2010 | 01:37 AM
  #85
marc97taws6's Avatar
Sumi's? WHY!
Old Dec 15, 2010 | 01:39 AM
  #86
LarsV8's Avatar
Originally Posted by marc97taws6
Sumi's? WHY!
heh, just need something to get it legal.
Will eventually see only drag radials
Old Dec 15, 2010 | 02:47 AM
  #87
CamaroRacing12's Avatar
HTR's! we sell those at my shop!
Old Dec 15, 2010 | 02:58 AM
  #88
carlos64030's Avatar
Interesting thread.
Old Dec 15, 2010 | 12:36 PM
  #89
Roadwarrior1956's Avatar
Originally Posted by LarsV8
That would be the unamed ebay special.
I got the same valve covers on ebay, check the bolt lengths very carefully, mine were TOO long and did not tighten the valve covers down enough, much oil leaking followed. I ground down the bolts @ a 1/4" problem solved.
Old Dec 15, 2010 | 09:14 PM
  #90
Torque Fiend's Avatar
everything is great and the to do list too.
However, DO NOT ADD WIRE LOOM, unless it takes over the stock stuff, in the exact same spots in black.
Old Dec 16, 2010 | 01:33 PM
  #91
Turnin20s's Avatar
Whats wrong with sumis?? I have had them for a couple years now and don't really mind them. They don't really hook, and when their hot you might as well be driving on ice, but they wear like rocks LOL
Great build, keep up the good work and keep posting pics Makes me want to go work on mine, but I have no time and 2 cracked ribs (damn ice)
Any suspension plans??
Old Dec 16, 2010 | 01:53 PM
  #92
atrain59's Avatar
Nice job keep up the good work
Old Dec 16, 2010 | 04:29 PM
  #93
meine96ws6's Avatar
I am giving you a bunch of credit for tracking such a good build.. And you are explaining everything really well.. i'm checking this for progress and motivation.
Old Dec 24, 2010 | 05:21 PM
  #94
LarsV8's Avatar
Thanks!
I know I am a novice when it comes to doing this stuff. I learned alot and used these forums often for advice. I want to put my work out there so the next guy that comes along can avoid the mistakes I made.
Anyway, heres a video!
I have some concerns.....
Why is my oil pressure so high? Is that normal for a fresh rebuild? I used Rotella SAE 15w40 for break in.
Old Dec 24, 2010 | 05:41 PM
  #95
flyinZ's Avatar
Back when I used to run that oil, when the engine was COLD, it would go up to 60psi and if I touched the throttle just a little bit, it would go up. It never pegged the oil PSI gauge, but it'd go up. Once it warms up, does the psi settle down, around 50psi?
Old Dec 24, 2010 | 06:25 PM
  #96
LarsV8's Avatar
It's not legal yet so I can't drive it around to heat up. I don't want to idle for to long either as that's supposed to be bad for break in.
Old Jan 23, 2011 | 04:43 PM
  #97
Camaro93's Avatar
Glad ya kept it , and still had the passion to work on it after all those years. Sucks you chipped that bearing but look at the cause of that now ...man oh man that engine is nice , 4 grand? 5 grand? Man I don't even wanna know. Nice car keep it forever.
Old Jan 23, 2011 | 07:40 PM
  #98
LarsV8's Avatar
I appreciate your enthusiasm!
Old Jan 23, 2011 | 07:45 PM
  #99
fergymoto's Avatar
Your bearing clearances are probably on the tight side and between the weight of the oil and the cold temps the pressure is high. The builder probably put a high volume pump in it on top of that. What weight did he say to run after break in?
Old Jan 23, 2011 | 09:03 PM
  #100
1961ba427's Avatar
Yeah, I'm sure that it will settle down after you break it in and pour in some 5w30.
I'm enjoying following this thread. I'm about to start tearing into my gf's 95 Z28 M6. It's gonna be a long build due to budget and lack of time.
