Help pushin a stockbottom end lt1 into the 10s
#61
thanks for the help guys! heres a couple of timeslips,
60' 1.522 1/8 7.043 95.66 1/4 11.123 121.13
60' 1.511 1/8 7.066 95.40 1/4 11.158 120.88
weighed the car last night at nyirp and it was 2900 without me and 3110 w/me. There is no metal cut outta the car brackets and all are intact so there is room to go lower.
The car ran the 11.12 with my friend driving (he weighs 170) and the 11.15 with me (210)![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Wow I need to get down to 3100lbs raceweight. Nice times. Looks like you need to get your 60' down to 1.4's, you can run 10's. Goodluck
#62
Hey I was just out in the garage and was looking at my ls1 swap and noticed the alternator is tiny compared to the lt1 unit. Is this a direct swap? the pulleys look to be different sizes but they could be changed
Hey Gizmo the car still has the stock torque arm rear springs and shocks, would the most gain in 60ft come from a higher stall converter?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#65
R/T .563
60' 1.524
330 4.518
1/8 7.061
MPH 96.02
1000 9.266
1/4 11.117
MPH 122.14
I purchased a chrs1313 ram air kit from Speed Inc and will be installing that but then im kinda at the point of cam or converter again.
#68
Jay--what size rear tires are you running? Just want to know the height really. Maybe someone has a slightly shorter tire you could try out to see what happens. A shorter tire would help the gearing and get the car out of the hole a little better. You are SOOOOOO close man!
#69
#70
I realize at this level tenths are difficult to come by, and the lid without a doubt picked up the car at the least a tenth. I would have to say it was definately worth it but should warn that the way that I did the swap (no metal cutting) was very costly and involved. The glasstech 4" cowl hood did not fit my car without trimming.. alot... off everywhere.. but yes worth it.
Hey Joel I have the 275 60 15 mt drag radials 28"inchers I beleive.
#74
I look at that picture and I can see 59lbs of stuff you can take out in 10 minutes flat.
Passenger seat (35ish) , both door panels (16-17), and passenger seat belt (6).
That's 58-59 right there. Might sound trivial but you will kick yourself in the *** when you go out and run a 11.000000000 lol.
#75
I was just looking back through the post and seen you have an SLP Catback on the car. Do you think it would benefit you enough to run a x-pipe setup with bullets dumped before the axle? Could be a few more ponies.
#77
Thanks everyone for the help and positive comments, I have put this combo together based on everything I either read or was told from here over the years here.
PS The silver car in the background is not for sale so please stop with the pms
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#78
Still have the slp on there, it seems like a decent light, free flowing exhaust so I didnt really think about any power there but would consider anything at this point really
PS The silver car in the background is not for sale so please stop with the pms![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#79
Jay-- did you race last night? A bunch of my friends went to Empire. It hit negative DA late in the night. At 8:54 it was -65 feet and at 9:54 it was at -145 feet. You would have gotten your 10 without a doubt.
