Anyone running the LE 226/230 .565/.565 111 LSA cam?
1 Post
I can get this cam brand new for $220 Just wondering If anyone has had good results with it? I just installed some LE1 heads and This cam seems like it would be a decent bump in power over the hotcam I have now. What Knd of power are you making and what track times are you guys running with this cam?
last year I was running a LE 224/230 grind same lift on a 112lsa and My numbers are in my sig. My valves were set to loose at the time too soo. With that cam you should deffinitley see a good increase over your hotcam.
1 Post
Ok so 15rwhp over the hotcam. Ive read that 1.7 rocker are good for around 15rwhp as well. Swapping rockers would be alot easier and cheaper than a cam swap for the same gain.
A 15rwhp gain over the hotcam was a pure guess, talk to Lloyd he will give you a more accurate guesstimate but you might as well take advantage of those good heads with a good cam that was probaly designed with those in mind. You can bandaid the hot cam with 1.7RR's so it has a little more lift but you still don't have the duration, more aggressive lobe design, more modern technology just to name a few things, IMO of course.
Me either, personally with a good tune I see you gaining over 15rwhp if you have the supporting mods. Do you have any idea what your car is putting down with the current setup?
1 Post
The car made 318rwhp through a locked a4 and ran 14.0 @ 98mph I then added a ls1 lid setup and ran 13.8 @ 100 mph. I took it to the track after the head swap and only ran a 13.6 @ 101 mph. remember I'm in colorado so the da is killing my power 7300 da.
