g.t.p heads
Guest
Posts: n/a
I ran a set of GTP LT1 heads and the GTP #5 cam on a stock shortblock and a full weight car into the high 11's ....also ran the heads on a 396cid Shortblock with a 222/228 .544/.538 112lsa, this setup made 422whp/447wtq and ran mid-low 11's at 116-118 in a full weight car.
I think Chris Marsh's heads off his '93 were Craig's guinea pigs? I saw him run several deep 11 second passes at 118 to 120mph on the stock short block. Somewhere between '96 and '97.
Yeah any decent ported LT1 heads/CC306 or similar, with all the supporting boltons should trap 120+mph depeding on weather, tune, traction, gearing etc... My car ran 11.20@120.8mph nothing speacial, old 355"LT1 with a CC306/ LE heads, 4-5yrs ago also thru an auto to boot. I don't see why people make a big deal on one particular piece of a combination like heads and cams. If I listened to everyone I would swap cams every other week. Every combo needs to be fine tuned, tweaked and setup properly to work right. I bet if I gave 5 people each a set of AI heads/cam to put on a stock shortblock you would have one that smokes them and that would be the one person who understands how to setup the rest of the car to go along with the added HP. Look at some higher Hp heads/cam cars that trap 120mph but barely runs 11's. I would rather run 116-118mph and run 11.20-30's b/c that is alot quicker et wise. Not trying to hurt anyones feelings just an example of more HP doesn't always mean quicker ET's. I have a friend with a heads/cam LS1 and he has been 11.80's@120mph but mostly runs 11.90-12.20's in normal weather. He put down more rwhp then I used to on the dyno and I ran almost 1 second quicker then he did, 11.00's@123mph with my 350" heads/cam LT1. My car is a little lighter 3,450lbs< 3550lbs, also he has a 6speed so he dyno'ed more but ran alot slower. Later Clint
#32
Not everyone's car is setup for drag racing. Hell I haven't been to the drag strip in over 2 years. I personally thing going WOT for 11 seconds in a straight line is boring as hell, especially with an auto where all you do is push the gas pedal to the floor. Road racing on the other hand is a different story.
#34
thanks for all the positive output . like everyone else im on a tight budget as havin 2 kids and so on . i have the build sheet now on these heads and there a stage 3 setup flowin 300cfm at .550 lift and so on . im doin a duff cam at the same time over the winter then its time for another dyno tune lol
#36
Good post! It's nice to see a constructive LT1-head thread for once
Craig definitely knows LT1/LT4 heads. He reworked a set of butchered heads for me in the past taking my car from trapping 113mph to 121mph with NO other changes other than re-tuning the car for the reworked heads.
GTP is good stuff!
GTP is good stuff!
