g.t.p heads
Old Jul 9, 2010 | 04:28 PM
93v8clone's Avatar
Default g.t.p heads
i found a set local for 1200 bucks, they were on the motor for about 2 months and he spun a main bearing . that bein said they are a stage 3 setup has the build sheet and so on . are these a good head or not so much they will be goin on my car over the winter with a new cam if the opinions are good lol
Old Jul 9, 2010 | 05:11 PM
SS RRR's Avatar
Village Troll
Craig Gallant of GTP was one of the first head porters to modify LT1 heads in the early 90's. He's responsible for many f-bodys in the mid and low 11's at 118 to 120mph with the 306 cam with all the bolt-ons back back then. I'd snag those no questions asked. If your car is set up right you will not be disappointed.
stryker1320's Avatar
Back before Lloyd Elliott and AI were on the scene, GTP, LPE, and CNC Cylinder Heads were the places to go to get your heads ported. In their day they were all top notch but AFAIK Lingenfelter is the only place of the 3 still going. GTP's stage III heads were the best they offered. I had a running buddy who had a set of their heads and he was more than satisfied with them.
Old Jul 9, 2010 | 05:15 PM
SS RRR's Avatar
Village Troll
http://gtp-racing.com/
Old Jul 9, 2010 | 05:21 PM
Originally Posted by SS RRR
Lol, I knew that would happen and that's y I put AFAIK in front. I stand corrected then. I guess you just don't hear much of them in the LT1 world much anymore and if I didn't live a half hour away from lingenfelters shop I probably wouldn't hear as much from them either.
Old Jul 9, 2010 | 06:42 PM
Puck's Avatar
Craig was arguably one of the best head porters available at the time.
His business is still around, but they are not as big on the LTX scene. For $1200, if they really are the level 3 heads, I would jump on them in a heartbeat.
Old Jul 9, 2010 | 07:01 PM
Z8'S's Avatar
Craig Gallant builds the best LT1/LT4 heads out there. BARNONE.
Old Jul 9, 2010 | 07:09 PM
Puck's Avatar
Psh, what's this noob know about GTP or LTX heads?? He hardly ever even posts!!!
Old Jul 10, 2010 | 01:15 AM
93v8clone's Avatar
they are the stg3 heads i looked at the build sheets and the heads tonight . there only 1 yr old as the machine shop that built my motor only uses him . so i did trust em to a point . im glad to hear this so ill be gettin these heads today then and i guess its time for a new cam lolol
Old Jul 10, 2010 | 04:49 AM
Easy there trigger. Just because someone has a low post count or a fairly new join date doesn't mean they are a noob. Now I know that wasn't directed toward me, and his statement is a little stretched, but come on now. I have been at this for quite some time now (early 97, but not on this site), and I still remember some of your first questions and statements over on CZ28.com.
Old Jul 10, 2010 | 07:24 AM
SS RRR's Avatar
Village Troll
You don't get jokes.
Old Jul 10, 2010 | 08:12 AM
I was wondering, but its kinda hard to tell it was a joke with the extra question marks and exclamation marks. Not to mention the lack of Smileys.
Old Jul 10, 2010 | 09:41 AM
Puck's Avatar
It's Sikora, or course he knows his ****. I would take his advice as Gospel any day of the week .
Old Jul 10, 2010 | 09:46 AM
Z8'S's Avatar
LS1 tech.com ......................... Where you're only as smart as your post count!!
Old Jul 10, 2010 | 04:48 PM
Z8'S's Avatar
I'm willing to put my Heads(That Craig did) up against anybody else's .
Old Jul 10, 2010 | 05:45 PM
93v8clone's Avatar
with my combo and a cam similar to the cc306 specs what could i expect out of my setup
Old Jul 10, 2010 | 07:28 PM
SS RRR's Avatar
Village Troll
Impossible to say, but if it's set up, tuned right and mechanically sound you should be well into the 11's N/A.
Old Jul 10, 2010 | 08:29 PM
93v8clone's Avatar
i knew i wasnt gonna get a dead set time or number lolol . just tryin to get a rough idea between the new h/c/i combo i need a better susp under the car . i also bought a lt4 intake with these heads that was port matched to these heads
Old Jul 10, 2010 | 09:55 PM
Puck's Avatar
I second that emotion . Anything 23*s can bring it .
Sure, its expensive and takes a ton of man hours, but you can't replicate what a talented individual can do by hand with a pre-written NC script.
To the OP, your build should run mid-low 11s depending on your setup. My stock cube build with a 227 grind pulled consistant 11.7-11.9s with shitty hogged out heads and a much smaller cam. It was a full interior DD street car with only a 3200 stall. Those GTP heads are a ton better then what I had, and more cam will help assuming you have the gearing to use it.
Old Jul 11, 2010 | 07:39 AM
SS RRR's Avatar
Village Troll
Looking forward to seeing results of some more GTP setups.
