CLUTCH ADVISE for built lt1
Old Aug 1, 2010 | 05:56 PM
GITSUM95Z's Avatar
Default CLUTCH ADVISE for built lt1
ok for starters, i have a 95 camaro,lt1, 355,306 comp cam,1.6 rockers, ported heads&intake,srp pistons,eagle rods, eagle steel crank, 58mm bbk, msd everything, under drive pulley's, crs elec water pump, long tubes, dual 3" x pipe all the way to back, all suspension up grades, moser 9", spool, 457 gear, looped and frames tied, umi torgue arm relocator transmission brace, 175 wet kit, 6 point cage. i have ran a centerforce dual friction for the last 5 years. my problem is they are not selling them anymore, just dfx.
MY QUESTION; im on a budget right now, so... has anyone used a ram hd clutch or is there one that is similar to the dual friction. i had such good luck with df clutch i want something similar without blowing my budget. any help is greatly appreciated!
Old Aug 1, 2010 | 06:04 PM
69gto96z's Avatar
I am using the Mcleod single disk with a stock pressure plate. It has held up good for 40k miles and a few years behind a stock head/stock bottom end and a comp 306. I do not launch the car hard though, because I do not want to break my 10 bolt.
Old Aug 1, 2010 | 07:49 PM
speed_demon24's Avatar
No complaints with my ram powergrip HD except rear end carnage. It drives pretty close to stock with no chatter.
Old Aug 1, 2010 | 07:54 PM
z_speedfreak's Avatar
you cant get a new disc for the dual frictions? I picked one up for mine last summer
and isnt monster workin on a kit for us LTx guys? that out yet?
Old Aug 1, 2010 | 08:56 PM
97Z28SS's Avatar
Check clutchnet.com that's where I got my 6 puck.
Old Aug 1, 2010 | 11:17 PM
alexcoreas's Avatar
I had the dual friction, and spec 2+ is just what you need, ram hd is amazing as well. Clutch net is a great place also.
Old Aug 2, 2010 | 11:34 AM
That wouldn't even come close to holding the power of a h/c/nitrous LT1. After I took out my mcleod single disk I decided that I'll never run a dual friction again. The less grippy friction side is always the weak link. The clutch only had around 30k on it.
Old Aug 2, 2010 | 06:14 PM
Wicked94Z's Avatar
^^^great clutch^^^ ran one for about 20k miles or so, pulled it off and it had plenty of life left. sold it for like 100 bucks
Old Aug 5, 2010 | 06:50 PM
GITSUM95Z's Avatar
THANKS EVERYONE FOR REPLEYS!!!!! yeah i think im gonna give the ram hd a try. yes they do sell the clutch disc for dual friction but i was told by centerforce themselves that i have to buy it as a kit. also he told me that they dont make the dual friction right now, they are retooling for a better dual friction. they offer the dfx for lt1's but thats outta budget.
Old Aug 5, 2010 | 07:46 PM
killagt's Avatar
is heavy clutch mean can handle more power ?
Old Aug 5, 2010 | 08:03 PM
udlose99ta's Avatar
I've had spec, ram, centerforce DF and DFX. DFX FTW!! best clutch i ever had.. blew my car up and now my buddy runs the disc in his 10 sec n/a 6.0. Since the DFX is out of your budget I would also recommend the powergrip
Old Aug 5, 2010 | 08:05 PM
chavez885's Avatar
I've been a fan of ram clutches. My next clutch for NAWZZZZ will be a ram powergrip HD.
Old Aug 5, 2010 | 09:50 PM
RyanSws6's Avatar
I've got a CF dual and was going to buy another on for my 383. On my 408 I bought a 12 inch CF and SMOKED it in 500 miles!!! So with 25k and 4yrs on my LT1 the CF was/is great. Guess I may go RAM with my new setup...
Old Aug 6, 2010 | 01:16 AM
check with byunspeed! just remembered thats where I got my replacement disc just last summer
