LT1 Carb conversion questions...
Hey guys, straight to the point-
I have a low mileage LT1 that came out of a 94 Z28, and I have a 79 Camaro in need of a new engine... I have the original 350 still in the 79 and it runs fine but with the outrageously high miles on it i think its time for a new one
So I was first looking into converting the Camaro to FI, but there are a lot of complications with it (esp having to drill into the gas tank) plus I figure it would be more cost effective to pop the LT1 in there as a carbed engine.
What all would I need to convert the engine? I've already got a new (1yr old) carb intake off the original engine as well as a distributor... can anyone give me some insight on what I'm getting myself into?
first off you would ned to buy this front plug
http://www.summitracing.com/parts/NAL-12367600/
second the intake you have did it come off of a old sbc? if it did you will need to have the intake holes re drilled so you can bolt it down to the lt1 heads.
1994, 350, 35o, carb, carburated, carburetor, cocvereson, conversion, convert, drop, intake, low, lt1, lt4, mileage
