Opti spark
Old Aug 23, 2010 | 08:33 AM
1994 interceptor's Avatar
Does anyone know if I have to take off the balancer to replace the optispark???
Old Aug 23, 2010 | 08:50 AM
wrd1972's Avatar
Yes you must pull the balancer but NOT the hub on the front of the crank.
Old Aug 23, 2010 | 11:44 AM
What do u mean b not the hub on the front of the balancer?????
Old Aug 23, 2010 | 11:47 AM
Does anyone know where I can get an opti wire harness
Old Aug 23, 2010 | 11:50 AM
fupa's Avatar
I got one from EFI Connections, I dont remember the exact link they had for it (its not the same as there efi connections home page and I dont think its listed) But you could just send Mike or someone over there a quick message and they can hook you up. I think it was about 35 bucks and there stuff is top notch.
edit found the link http://www.optisparkharness.com/opti...s/default.aspx
Old Aug 23, 2010 | 12:56 PM
RamAir95TA's Avatar
The balancer/pulley assembly bolts to the crank hub. It's held on by 3 bolts. You may or may not need to use a puller to pull it off if it has never been off before.
EFIconnections. The link is already posted.
Old Aug 23, 2010 | 01:30 PM
ChandlerMotorsports's Avatar
Originally Posted by 96capricemgr
The cap and rotor are like any other distributor WEAR ITEMS but the ignorant folks of the LT1 community prefer to ignore it till it wears out them blame "bad design" and pretend the whole thing died instead of just a worn out cap and rotor.
This is not entirely true. Its definitely a maintenance item BUT the ignition module inside fails when people also don't maintain their water pump. It leaks into the unit and then game over from there. Hitting puddles, aggressive car washes (pressure washer to the engine) are also another way to put an optispark into the grave.
Also, as far as the MSD cap and rotor. We've had people compare the MSD units to our cap and rotors and people have kept ours at a fraction of the price of MSD.
Old Aug 28, 2010 | 07:28 PM
Once I rePlace the opti when would I need to replace it again
Old Aug 28, 2010 | 07:31 PM
jkicak's Avatar
next time it dies..........
Old Aug 28, 2010 | 08:00 PM
ORedRoc4's Avatar
Just a quick thought, you may want to try and clean off the MAF, a random non-missing stall at idle is an indication of this. Plus its really easy and cheap to clean the MAF quickly with MAF cleaner, maybe $6 at autozone. Worth a try IMO as i catch myself having to do this every couple of months.
Old Aug 28, 2010 | 09:37 PM
Speedy's Avatar
You need to do the cap and rotor every 40,000 miles. The entire opti unit should be replaced every 80,000 miles to be safe. Some last over 200,000 miles, but age and corrosion become factors. It's not such a big deal. Changing timing belts on 4cyl cars is usually worse.
Old Aug 29, 2010 | 05:33 PM
  #32
IronOutlaw's Avatar
Get the icm tested to be sure. That's free and very easy to remove. Mine was doing the same thing yours is a while back until it just died one day going down the road. I was thinking opti but turned out it was the icm. Aka ignition control module.
Before you ask it's on the front of the drivers side head connected to the coil.
Old Aug 29, 2010 | 05:45 PM
  #33
RamAir95TA's Avatar
There is absolutely nothing in any year LT1 f-body's owners manual that say anything about changing the cap and rotor is mandatory at XX,XXX miles (or ANY amount of mileage for that matter).
If it isn't broke, DON'T FIX IT.
Old Aug 29, 2010 | 10:28 PM
  #34
I thought it was the icm had it tested and it was fine
Old Aug 29, 2010 | 10:32 PM
  #35
Does any one have a under drive balancer pully for sale
Old Aug 30, 2010 | 09:14 AM
  #36
Would anybody know if the parts from Chandler motorsports are any good??
Old Aug 30, 2010 | 01:12 PM
  #37
How can I tell if I have a vented or non vented opti???
Old Aug 30, 2010 | 01:15 PM
  #38
RamAir95TA's Avatar
They aren't even worth the effort looking for them.
They have been getting good reviews, but there's still something that bothers me about a $90 optispark.
93-94 optisparks are unvented, 95+ are vented. Vented optisparks have two vacuum lines going to them. Unvented optis have a spline drive, while vented optis are pin-driven.
Old Aug 31, 2010 | 12:36 PM
  #39
https://ls1tech.com/forums/lt1-lt4-m...torsports.html
Old Aug 31, 2010 | 08:44 PM
  #40
Speedy's Avatar
Take a better look at any service manual, including the Haynes, Chilton or any other. Like any distributor the recommended "inspection interval for the distributor housing" is 30,000 miles specifically for the 5.7 LT1 engine.
30,000 miles has been the service interval for every distributor since the HEI came out in 1973. Any contact distributor is the same. I stretch it to 40,000 miles because I can. And I'm cheap.
