396ci LT1 Convertible Race Car Build
#64
Those 456 gears are serious; definitely not messing around.
Wicked project dude - and props for you doing so much work yourself and at home. BEST best about your entire build? - that carpet in your garage! (serious), throw a lazyboy in that garage with a little beer fridge and radio and you're golden![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'll answer for him since he's been so busy about the progress...it's still on hold. Once he gets a few odds and ends together (mostly trans parts like flywheel, dipstick, etc.) then we'll start putting it together. It's still a long ways off, but hopefully it will be ready to fire in the springtime.
#65
Sorry guys, lots going on - moved to PA, new job, traveling a lot for work, planning a wedding, buying a house.......life happens.
Soooooo - Pulled entire wiring harness yesterday, identified all unnecessary wiring. Engine and trans will be in next weekend. More updates/pics ASAP!
#69
**PICS ADDED TO FIRST POST**
Engine/trans are in. Fuel lines were pulled for re-routing via -6AN lines. Pulled all wiring in the engine bay back to the firewall - deleted any wires not needed, cleaned up fuse boxes - re-loomed and re-routed all wiring for a crisp, clean look. I will post pictures of that later this week. Enjoy!
#71
http://snyder-fab.com/
#79
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
I took pictures last night and will post them after work today. To summarize:
-Removed the entire chassis wiring harness - replaced with a Painless setup and a Painless 8-rocker switch panel. Rewiring the entire car with that now.
-Dash is back in the car.
-Seat, steering column mounted and ready to go. Carpet will go back in once wiring is finished.
-Billet Specialties wheels, M/T Drag Radials, and a package of goodies from Madman will all arrive tomorrow.
-Car will go back to Snyder Fabrication for final chassis prep and some tweaks on February 15th. I expect to have it at the track after a PCMforless Dyno Tune in APRIL!
Check back tonight for pics.............
