crank sensor
Old Aug 28, 2010 | 04:55 PM
Cam95Maro's Avatar
Default crank sensor
Kinda a dumb question butdo our cars have a crank sensor and could this be the issue I'm having with car sputtering when i sit at idle cause now my speedometer when I floor it and get closer to high rpms it starts bouncing around my speedo and my tach both are bouncing around .... a friend of family told me about it but isnt sure if we have one so I will ask yall
Old Aug 28, 2010 | 05:18 PM
Badazz 97 TA's Avatar
96 and 97 LT1 f-bodies did. what year is your car? previous years did not have one
Old Aug 28, 2010 | 05:28 PM
SS RRR's Avatar
Village Troll
The crank sensor is read only. They do nothing more than detect misfires.
Old Aug 28, 2010 | 05:36 PM
Cam95Maro's Avatar
Mine is a 95 so I don't got one alright also when my car throws a check engine light does it store in the computer cause it comes on and goes off and I wanna see if I can still figure out what it was that it was on for
Old Aug 28, 2010 | 05:45 PM
RamAir95TA's Avatar
Like mentioned, CPSs were only used on OBDII cars.
As for the CEL, no use in guessing - have it scanned. That's what it's there for.
Old Aug 28, 2010 | 06:47 PM
Cam95Maro's Avatar
I know I am going to but the only problem is it isn't on all the time does it store it in the computer as like a recent check engine light,or w/e
Old Aug 28, 2010 | 07:09 PM
yeah it should. I believe 95's had the obd1 computer but a obd2 port. so it might be tricky finding a scanner unless you just take it to the dealership
Old Aug 28, 2010 | 07:13 PM
Cam95Maro's Avatar
I was thinking about taking it to dealer cause this problem has just been a pain in my *** oh and RAM air I tested fuel pressure outta pump 47 and fuel rail close to same I'm starting to think it night be distributor
