headers question (a.ir. or e.g.r)
Old Aug 28, 2010 | 10:39 PM
ryanosborne's Avatar
Default headers question (a.ir. or e.g.r)
i dont understand.. do you need accomodations for e.g.r or a.i.r im ordering a set od pacesetters and i ordered the ones without it but should i change the order? my car is a 1994 firebird formula http://www.summitracing.com/compare.aspx
i ordered the ones on the right.
Old Aug 28, 2010 | 10:44 PM
by the way , there are no emmision testing here
Old Aug 28, 2010 | 10:51 PM
Tolley's94z28's Avatar
well if you ordered the off road long tubes then you are going to need an egr block off kit, it is just a couple plates that bolt onto the back of the intake.
you can buy them on summit for like $30 i think
good luck with your new upgrade
Old Aug 28, 2010 | 10:57 PM
what would be better/ easier? because my money order hasnt reached them yet so i could change my order or work something out with them
Old Aug 28, 2010 | 11:02 PM
to be honest its sortof up to you, i mean if your decent with a wrench and would like to clean that cluttered engine bay up then keep the off road ones.
thats what mine are, but i just like wrenching on **** so the harder it is to do, the better lol
but if you want the somewhat "easier" approach then buy the ones with egr hookup, headers are headers, either way its gonna take some work and patience and a busted knuckle or two haha
Old Aug 28, 2010 | 11:04 PM
now having said all that, i do love how much cleaner it looks under the hood without all of that ****
Old Aug 28, 2010 | 11:06 PM
so its not important?
Old Aug 28, 2010 | 11:12 PM
i mean deleting egr isnt going to give you a performance increase to my knowledge, and i dont think ur worrying abt pollution too much since ur doing exhaust work to an lt1, its good to have a tune so you can delete those codes though, which gives you a few extra ponies as well in which case i recommend madtuner
Old Aug 28, 2010 | 11:21 PM
i just wanted to make sure i wouldnt loose any power deleting the e.g.r or the a.i.r
Old Aug 29, 2010 | 12:27 AM
oh you wont lose any power, if anything it helps more than it hurts, so go pick up a six pack and rip that **** out! lol
Old Aug 29, 2010 | 01:25 AM
RamAir95TA's Avatar
You won't lose any power, but you will not gain any power either.
Old Aug 29, 2010 | 11:27 AM
so whats the whole point of it if it seems so useless
Old Aug 29, 2010 | 11:29 AM
what do i need to block off the a.i.r and egr? where can i order it from
Old Aug 29, 2010 | 11:35 AM
RamAir95TA's Avatar
Deleting the AIR and EGR is for cosmetic purposes. It cleans up the engine bay tremendously.
There are several kits available. Do a search for "EGR block-off kit" and you'll get tons (most site vendors carry something, try LS1speed). Several are also available on eBay. To delete the AIR pump, you'll need either an M18 (OBDII) or M22 (OBDI) drain plug and a 5/8" vacuum cap.
Old Aug 29, 2010 | 11:39 AM
do you know wich sponsors on here could supply me with all of them parts?
Old Aug 29, 2010 | 11:47 AM
Z28Roxy's Avatar
Just run the offroad headers (I wish I did, I have plugs in mine and they look stupid).
If you do that you won't need to buy anything as far as AIR pump stuff goes. As far as EGR, something like this:
http://cgi.ebay.com/ebaymotors/93-97...Q5fAccessories
is all you will need.
Old Aug 29, 2010 | 12:03 PM
perfect what will i need to put where the air pump goes?
Old Aug 29, 2010 | 12:12 PM
Z28Roxy's Avatar
Uh you just unbolt it from the bracket. Then unbolt the bracket from the block.
There won't be any holes in the headers with the ones you are getting that need to be plugged. You'll need a rubber vacuum cap or two and that's it.
Old Aug 29, 2010 | 01:33 PM
atlanta15braves's Avatar
Default pacesetter off road long tubes + y pipe
just get the delete kit from summit that was mentioned earlier, in the end it might end up sounding like this.....http://www.youtube.com/watch?v=XClImvvXbNs. I start to get on it at like 20 seconds. Maybe send a video of yours after you finish?
Old Aug 29, 2010 | 01:36 PM
RamAir95TA's Avatar
Deleting the AIR and EGR won't change the exhaust note at all. Not sure what you're getting at...
