wrong crank hub?
http://www.google.com/imgres?imgurl=...w=1280&bih=809
if you didnt put the reluctor ring on you have to use the 94 hub, if you used the reluctor you have to use the 96/97hub or cut the 94 hub down the difference of the thickness of the reluctor.
you should be able to find a length for each and then measure yours and find out what you have..
OP, like brucer said. If you're using the reluctor wheel, 96-97 hub...
If you're NOT using the reluctor wheel, 92-95 hub. Simple
94 lt1 camaro, 96-97 style timing cover, vented opti, no reluctor wheel, obd1 lol
from what i understand the snouts are different.. i think this may be the later one.. the earlier (92-95) has the entire end polished..
I've got a '95 cover (vented opti) '95 hub (not for use with reluctor wheel) and I could REALLY use a '96/'97 cover and hub.
This is a long shot, but if you want to trade out for the right stuff for your car, pm me or something. The cover and hub I have are not going to be used, as I'm going with an lsx computer and no opti.
http://shbox.com/1/engine_front_diagram.jpg
It's a risky move to pull the hub on with the bolt.
