wrong crank hub?
Old Sep 8, 2010 | 10:11 PM
gregrob's Avatar
Originally Posted by shbox
It's a risky move to pull the hub on with the bolt.
Very true. (Speaking from experience)
Old Sep 9, 2010 | 12:03 AM
speedracer2536's Avatar
to be honest its all i have ever used.. what should i use to install the hub? i have never used anything different..
Old Sep 9, 2010 | 12:16 AM
gregrob's Avatar
A hub installer tool.
A homemade hub installer tool, consisting of HARDENED 7/16-20 threaded rod, hardened washers and nuts.
or my personal favorite, a 16oz soft dead blow hammer...
People will tell you all kinds of things that "could" happen from installing it with the hammer, but I havent heard of anyone actually having a problem they could trace to that.
I don't mean savagely beating the tar out of it, but using enough force to fully seat it. Never been a problem for me and I've done it several times.
Your call
Old Sep 9, 2010 | 05:56 AM
1961ba427's Avatar
I'm all for using the correct tool or a homemade one, but I think a hammer would be okay on the lt1 since it doesn't use a 2 piece steel or iron dampner that is bonded together with elastomer. I think that is why beating them on is frowned upon so. It can really loosen that bond and send outer rings flying.
Old Aug 4, 2012 | 09:40 PM
criticalx's Avatar
how much to cut off 93-95 hub?
Old Aug 4, 2012 | 09:53 PM
FAD2BLK93's Avatar
If ur beating it on with a hammer aren't u slamming the bearrings also? I dont mean u criticaix , i just mean in general. 0.100".
Old Aug 4, 2012 | 11:12 PM
warriorcustoms's Avatar
Just trade the guy that posted & youll be better off if its that confusing The only reason to keep the 96-97 cover is to do a 24x efi conversion Hell lots of 96-97 guys convert to the 95 style & Beatin **** on with a Hammer isnt really smart USE THE Correct TOOL for the job Even the all-thread & washers is a better Idea than beatin **** on anything Brains before Brawn while working on your motor The hub center is easy to mushroom The last idiot that owned my T/A did that already Good thing I bought the SFI approved balancer LoL
