how high of rpms is too high
The stock cam stops making power at 5500, so spinning past 6000 and you're just wasting RPMs.
8-9 years ago when I was bolt-on only, I was running in the high 12s with shift points set around 5800 with terrific results.
I had a gross case of this happen where I was crossing the traps in a past setup at 6200rpm when power peak was 5900rpm. Changed rear gears and gained 1.5mph through the traps and shaved off almost 2/10ths.
PS: You will also notice the 1/8th time 8.01 @ 87. (FYI: this was with a12bolt, 4:11's) That was done on a ET street (26x10.5x15) with a 5200 rpm launch and the car was still spinning and unloading at the top of my 60ft (hence only producing 1.8x 60's). I did not have the suspension tuning I have now and if I had at the time this car would certainly have run much stronger 60's. As a rule of thumb a 1/10th on the bottom is usually worth at least a 1/10th on the top and an extra 1 mph. Using conservative estimates, if I picked up 2/10th's from my 60 ft (1.6xx ish) that should plant me solidly in the 12.40/50 range and at least 1 mph to give me 110 plus trap speed. Anyway you slice it a 8.01 @ 87 in a full weight WS6 (except for the backseat) with bolt-ons and with the stock heads and stock cam is hustling!!
My point being, I produced those numbers shifting the car @ 6200 on the 1-2 shift and all other shifts done @ 6100 out the back door.
RamAir95TA:
"responded better" Simply means it produced better ET's
Most important, original poster: You can shift your car higher. Now returning this thread to OP.
My experience was different.
No one is really trying to go fast on the stock cam anyway, so who really cares.
Put something in there that wont die off
